Amp Internals 2 |
Page <1 244245246247> |
shaun1264 ![]() Registered User ![]() ![]() Joined: 06 September 2013 Location: Surrey Status: Offline Points: 242 |
Crown DC300A Series II. Well used. Original components, Still running well after all these years. Another one of Crowns Gerald Stanleys designs. Amazing clever early design. Topology is the patented class AB+B. The outputs carry no bias. Outputs are lowish bandidtrh but durable. The drivers run in class AB. The outputs act as "boosters" in Class B over a certain wattage. Very low THD, low DC offset and good power down to DC. ![]() ![]() ![]() ![]() Output just before IOC lights show into a 8ohm load
Edited by shaun1264 - 12 March 2023 at 8:16pm |
EmPro ![]() Registered User ![]() ![]() Joined: 26 June 2020 Status: Offline Points: 356 |
This design among with Ground Bridge design are the legends that made Crown a trusted and well reputed PA manufacturer...
![]() Edited by EmPro - 12 April 2023 at 9:23pm |
EmPro Audio
M4trix ![]() Registered User ![]() ![]() Joined: 23 June 2009 Location: Croatia Status: Offline Points: 425 |
Now imagine those days when you had to populate the board without component markings printed on PCB. Pain in da arse !
kedwardsleisure ![]() Old Croc ![]() Joined: 20 January 2009 Location: Staffordshire Status: Offline Points: 4813 |
I doubt they'd be hand built, the auto insertion machine would know where everything went!
North Staffordshire |
4D ![]() Old Croc ![]() Joined: 13 November 2008 Location: Winchester Status: Offline Points: 4221 |
Qsc EX4000 Edited by 4D - 13 March 2023 at 8:01pm |
Some serious amps there 👍👍👍👍
EmPro Audio
A lot of iron there. Good. Iron deficiency can cause all sorts of problems like, fatigue, shortness of breath etc.
can see a few domed/vented capacitors by the looks of it, expensive repair!
These are some of the amps I mentioned in another thread as I was quoted £380.00 per amp to service, replace the 24 capacitors, redo the thermal paste reset bias etc . I have sent one in to be done as a test & will collect early next week..
Edited by 4D - 14 March 2023 at 10:44am |
NAD CI9120.
At over 80lbs I can see why they call them 'Nads'. ![]() ![]() |
voron ![]() Registered User ![]() ![]() Joined: 05 April 2009 Location: Russia, Tver Status: Offline Points: 164 |
Edited by voron - 18 May 2023 at 10:21pm |
New one on me!
Samick SMP-4000 2 x 200W into 4R Being used as the main PA for a 5-piece rock band. Really. ![]() ![]() |
