  New Posts New Posts RSS Feed - Amp Internals 2
Amp Internals 2
 Post Reply Post Reply Page  <1 236237238239240 260>
Post Options Post Options   Thanks (0) Thanks(0)   Quote Earplug Quote  Post ReplyReply Direct Link To This Post Posted: 09 June 2021 at 5:29pm
Yes, who knows. Amp designers are always trying to do things differently. Sometimes over complicating what should be a fairly simple process.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kedwardsleisure Quote  Post ReplyReply Direct Link To This Post Posted: 09 June 2021 at 10:54pm
probably more to do with impedance matching
North Staffordshire
Post Options Post Options   Thanks (0) Thanks(0)   Quote Earplug Quote  Post ReplyReply Direct Link To This Post Posted: 10 June 2021 at 6:08am
The cab has 4 x 12", 1 x 8" & 1 x 1.4".
IIRC, the amp for the 12's was standard Class G. Mid and top with the transformer.
From the spec sheet:-
  • Active, high-output, wide dispersion 3-way system
  • 80° x 70° coverage pattern
  • High output, 133dB in High Pass Mode Operation
  • Four 12″ high-precision transducers
  • Low distortion, horn-loaded 8″ mid-range transducer
  • 3″ titanium diaphragm compression driver
  • 18mm birch plywood construction
  • 1500W high-effi ciency, high-current amplifier for woofers
  • 300W Trans-Fet amplifier for mid-range
  • 150W Trans-Fet amplifier for compression driver
  • On-board acoustic management control system
"Trans-Fet" sounds to me like marketing speak BS, like the Carver "Magnetic Field" stuff. The extra cost of those transformers is a bit crazy. These days, the 8" & 1.4" would just be driven by a couple or 3 3886's or 7293's!  LOL
imageoven View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote imageoven Quote  Post ReplyReply Direct Link To This Post Posted: 10 June 2021 at 8:56am
Now known as LBGTQ+ Fets...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Earplug Quote  Post ReplyReply Direct Link To This Post Posted: 10 June 2021 at 9:10am
You should be on the Mackie Marketing Team!   LOL LOL LOL
mustang_flht View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mustang_flht Quote  Post ReplyReply Direct Link To This Post Posted: 27 June 2021 at 5:38pm
PAS audio 2002 PCA, Mosfet K1058 & J162 transistors. The amp is handcrafted in Germany.
Edited by mustang_flht - 27 June 2021 at 5:48pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote kedwardsleisure Quote  Post ReplyReply Direct Link To This Post Posted: 03 August 2021 at 3:23pm
Mackie FRS-2800
(complete with spare transistor front piece)
North Staffordshire
queen_of_spades View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote queen_of_spades Quote  Post ReplyReply Direct Link To This Post Posted: 04 August 2021 at 11:33pm
Anyone happen to have pics of Peavey CS1000 (not CS1000-X) internals, esp under the upper PCB where there are multiple spade connectors
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbl_man Quote  Post ReplyReply Direct Link To This Post Posted: 06 August 2021 at 4:53pm
"Anyone happen to have pics of Peavey CS1000 (not CS1000-X) internals, esp under the upper PCB where there are multiple spade connectors"
 Do these help at all? CS1000. not an X.
Edited by jbl_man - 06 August 2021 at 4:55pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbl_man Quote  Post ReplyReply Direct Link To This Post Posted: 06 August 2021 at 5:02pm
The 3 spades on the right, are in the correct order they came off the board, if that is what you wanted?  So white, grey, and then red.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kedwardsleisure Quote  Post ReplyReply Direct Link To This Post Posted: 17 August 2021 at 2:40pm
A bunch of shrivelled chevins.
North Staffordshire
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbl_man Quote  Post ReplyReply Direct Link To This Post Posted: 17 August 2021 at 3:19pm
That's rustier than a Lancia Beta. LOL
This page was generated in 0.297 seconds.
