  New Posts New Posts RSS Feed - Amp Internals 2
Amp Internals 2
 Post Reply Post Reply Page  123 235>
Post Options Post Options   Thanks (0) Thanks(0)   Quote kedwardsleisure Quote  Post ReplyReply Direct Link To This Post Topic: Amp Internals 2
    Posted: 03 November 2010 at 5:36pm
Peavey GPS3400
peavey by Electro Mechanic, on Flickr
Edited by kedwardsleisure - 06 November 2017 at 8:08pm
North Staffordshire
subbass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote subbass Quote  Post ReplyReply Direct Link To This Post Posted: 05 November 2010 at 4:11pm
Cloud MPA 626
swannie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote swannie Quote  Post ReplyReply Direct Link To This Post Posted: 16 November 2010 at 11:50am
Gemini XGA4000 power amp / 2x350w @4ohms (not 4000w as the front panel suggest's!!)
Dunlap Clarke Dreadnaught 1000 (mid/late 70's) 2x500w @4 ohms (weighs a ton!!)
Edited by swannie - 20 November 2010 at 9:44am
Wrighty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wrighty Quote  Post ReplyReply Direct Link To This Post Posted: 16 November 2010 at 2:30pm
Hz DPX600
ALL YOUR BASS ARE BELONG TO US.
Oldmaelstrom View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Oldmaelstrom Quote  Post ReplyReply Direct Link To This Post Posted: 16 November 2010 at 4:28pm
Dynacord AM12
Edited by Oldmaelstrom - 16 November 2010 at 4:29pm
Jez_3phaze View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jez_3phaze Quote  Post ReplyReply Direct Link To This Post Posted: 16 November 2010 at 11:11pm
Similar to Wrighty's Post! /\     Quote picture  removed, Apologies K.
My RDL PX 1100
550w RMS Per Ch@ 4 ohm /1140w RMS Bridge @ 8 ohm.
Edited by Jez_3phaze - 17 November 2010 at 12:05am
Post Options Post Options   Thanks (0) Thanks(0)   Quote kedwardsleisure Quote  Post ReplyReply Direct Link To This Post Posted: 16 November 2010 at 11:45pm
Do you think that posters can withold from quoting the previous post if it contains large pics, like the last example? I find the multiple repeated pics confusing.
Edited by kedwardsleisure - 16 November 2010 at 11:46pm
North Staffordshire
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wrighty Quote  Post ReplyReply Direct Link To This Post Posted: 17 November 2010 at 10:00am
My RDL PX 1100
Hmm, a remarkable likeness, yes! Heatsinking looks a bit better on the RDL. It looks a lot cleaner too. This Hz has had its front panel hand painted around the gold lettering with what looks to be black gloss Hammerite! It was given to me to look at by a colleague and may or may not have a fault...
Grumpy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grumpy Quote  Post ReplyReply Direct Link To This Post Posted: 17 November 2010 at 3:41pm
On that Dunlap Clarke Dreadnaught, the switch on the back marked “Max off Min”. Does it switch transformer secondary windings to give different power outputs, like the old Midas Cube Monitor Amps?
Edited by Grumpy - 17 November 2010 at 3:42pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote swannie Quote  Post ReplyReply Direct Link To This Post Posted: 18 November 2010 at 2:59pm
No the switch is for the fan on this amp, you can adjust the speed or simply have it turned off
Monitech View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Monitech Quote  Post ReplyReply Direct Link To This Post Posted: 19 November 2010 at 11:02am
now as john savage used to be a sales man for HZ
and martin savage used to own RDL does this not suprise you that they are simalar
regards
phoenix out of the ashes
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grumpy Quote  Post ReplyReply Direct Link To This Post Posted: 19 November 2010 at 11:06am
Thanks, was just curious
