Amp Internals 2 |
Post Reply | Page <1234 260> |
Oldmaelstrom
Registered User Joined: 07 October 2009 Status: Offline Points: 15 |
Made in Ukraine 4 channel class D power amplifier, rated power 350W per channel into 4 ohms
Edited by Oldmaelstrom - 19 November 2010 at 4:13pm |
Wrighty
Old Croc Joined: 17 April 2004 Location: Devon Status: Offline Points: 1801 |
I think I know where the inspiration for that front panel design came from...
ALL YOUR BASS ARE BELONG TO US.
kedwardsleisure
Have a look at this amp and tell me your thoughts! amptop by Electro Mechanic, on Flickr Edited by kedwardsleisure - 06 November 2017 at 8:12pm |
North Staffordshire |
M4trix
Registered User Joined: 23 June 2009 Location: Croatia Status: Online Points: 445 |
Enjoy repairing that wreckage. Probably you will need to replace the PCB too unless you wanna make wire jumpers over the damaged copper tracks. That PCB looks really nasty.
ceharden
I suspect after a good clean the damage won't look quite as bad. I'm curious what the amp is. I can't quite figure out the topology from those pics. Also I know one output stage is upside down compared with the other but they still don't look the same.
DjLeco
Young Croc Joined: 21 April 2009 Location: Bucharest Status: Offline Points: 817 |
ClassH 2 step!
Failed AB part from it, maybe oversized fuses, or fake 2SA 2SC output devices, the one wich burnt the 2 watts resistor are OPENED emitter, leaving the tension to chain burning other components , because the fuses did not blew when output devices fails...
Is an classical class H2 step OVERVOLT failing!
Very Bad!
I Bet is CHINA ONE! Edited by DjLeco - 19 November 2010 at 11:08pm |
andyamp
Old Croc Joined: 21 July 2007 Location: United Kingdom Status: Offline Points: 2115 |
yep not mde in the EU
http://www.matrixamplification.com/ |
cilla.scope
Old Croc Legs all the way to her bottom.... Joined: 02 October 2009 Status: Offline Points: 2954 |
it looks to be a single channel of 5+5 devices on the left, plus 2 channels of 3+3 devices on the right, mirror split half way up the PCB on the right if you look.
PSU has different raisl left and right side of the amp, I would guess the right side is 2 channels at a lower voltage than the left. just noticed its 5 DC supplies wires to each channel ... so theres a bit of rail switching going on Clearly purpose built as a 3CH, so most likely bass, mid, top from some sort 3 way box ... .looks too old/crap to be off a powered line array box .. Edited by cilla.scope - 20 November 2010 at 12:53am |
My girlfriend thinks I'm a stalker.
Well, she's not exactly my girlfriend yet ... |
Louder than loud
Old Croc Joined: 13 May 2010 Location: Guildford Status: Offline Points: 2377 |
i'll post a mackie swa amp up that went bang the other day lol ;)
swannie
Registered User Joined: 15 March 2008 Location: WEYMOUTH Status: Offline Points: 276 |
Rauch P-120 |
ceharden
Going back to the unnamed strange amp, I think Cilla has cracked it. Well spotted there.
Dilbert
Registered User Joined: 03 February 2010 Location: Northwich Status: Offline Points: 109 |
deleted.... just looked closer is this 3 channel? left hand side extra fan cooled bass & 2 x mid / tops on right with less cooling? Edited by Dilbert - 20 November 2010 at 1:00pm |
