  New Posts New Posts RSS Feed - Amp mod - bridging the unbridgeable
Biggus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Biggus Quote  Post ReplyReply Direct Link To This Post Posted: 10 February 2012 at 12:55pm
I emailed BK Elec a while back and asked if I could bridge a MXFamp and there said yes but only if you do something with polarity of one of the input channels and some other jiggery pokery you can bridge them. I didn't fancy doing this so sold the amp in the end and got something designed for the job. Let us know if your sucessful as would be good to know if it works. good old workhorses these.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Earplug Quote  Post ReplyReply Direct Link To This Post Posted: 10 February 2012 at 1:50pm
It sounds like it´s ok with these, but be carefull. I had a couple of Harrison mosfet amps (X1600?) that were already bridged internally so no. I´ve also seen some Profsound amps made in the same way.
More importantly, I´m pretty sure some of the Powersoft Digam amps use that trick, as well as the T-Amp D2800, D3400, etc, so maybe there´s a good reason some amps don´t have a bridge mode.
Edited by Earplug - 10 February 2012 at 1:53pm
