  New Posts New Posts RSS Feed - Amp parallel & bridged correct?
Jack1991 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack1991 Quote  Post ReplyReply Direct Link To This Post Topic: Amp parallel & bridged correct?
    Posted: 17 February 2020 at 8:29pm
Just checking im right in thinking that wired like this is correct and i will roughly get 150w rms per speaker/sub.
The amp is a 12v car amplifier, Pioneer GM-D8704 4 Channel Class D.
Specs:
Wattage RMS 4 x 100w @ 4Ω
Wattage RMS Bridged 2 x 300w @ 4Ω
The drivers are 2x identical 8Ω mid top speakers wired in parallel (to make 4Ω) and bridged to 2 channels on the amp. Then 2x identical 8Ω subs wired in parallel (to make 4Ω) and bridged on the other 2 channels of the amp.
This is exactly as it will be wired:
They are all PA drivers and going to be part of a 12v sound system i am going to build.
Cheers! 🙂👍🏼
Edited by Jack1991 - 18 February 2020 at 9:05am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Earplug Quote  Post ReplyReply Direct Link To This Post Posted: 18 February 2020 at 1:14pm
I´m not familiar with the amp, but the way you have it wired, you´re only going to get single channel power from 2 channels and the other 2 unused. For bridged use, the norm is to connect to the '+' on the 2 channels you´ve bridged.
Xoc1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Xoc1 Quote  Post ReplyReply Direct Link To This Post Posted: 18 February 2020 at 1:21pm
The diagram looks OK to me.
Usually Car amplifiers have 1 of each pair of channels phase reversed, and the terminals labelled accordingly, to make bridging easy.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Earplug Quote  Post ReplyReply Direct Link To This Post Posted: 18 February 2020 at 3:31pm
Ok, just downloaded the manual and it´s all there. And yes, odd wiring - not PA norms at all....  Confused
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack1991 Quote  Post ReplyReply Direct Link To This Post Posted: 18 February 2020 at 4:04pm
Cool okay im im unfamiliar with phase reversing?
I will double check that i am wiring it correctly to actually bridge 2 channels into 1 when i got the amplfiier. But what i would like to do will work all ok if so yes?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack1991 Quote  Post ReplyReply Direct Link To This Post Posted: 18 February 2020 at 4:06pm
Its a car amplifier not a PA amplifier. I just mentioned that im using PA speakers just incase that made a difference.
So will my idea work all okay though?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack1991 Quote  Post ReplyReply Direct Link To This Post Posted: 18 February 2020 at 4:07pm
The Amplifier speaker terminals
imageoven View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote imageoven Quote  Post ReplyReply Direct Link To This Post Posted: 18 February 2020 at 4:12pm
Yes
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack1991 Quote  Post ReplyReply Direct Link To This Post Posted: 18 February 2020 at 5:21pm
Yes
Straight to the point thank you 🙂👍🏼
Post Options Post Options   Thanks (0) Thanks(0)   Quote Earplug Quote  Post ReplyReply Direct Link To This Post Posted: 18 February 2020 at 6:32pm
Yes - it´s all on there, fairly obvious, but then the question is, if you want Mono Bridge, or Stereo.   LOL LOL LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack1991 Quote  Post ReplyReply Direct Link To This Post Posted: 18 February 2020 at 6:51pm
Mono is fine. Cool thanks, my main concern is;
1. That my 8ohm speakers/subs when in parallel would actually be seen as 4ohm by the amp when bridged.
And if 1 was correct then....
2. That as the amp puts out 300w rms @ 4Ω when bridged, if there are 2x subs/speakers bridged in parallel that is would share the 300w rms equally so each gets 150w (per bridged side) so essentially 4x 150w rms per sub and speaker.
Edited by Jack1991 - 18 February 2020 at 6:52pm
