Amp suggestions needed. |
Post Reply | Page <123> |
Earplug
Or Crest 7001's. Lovely little amp for a small rig.
FOO
Young Croc Joined: 23 December 2018 Location: Denmark Status: Offline Points: 813 |
Well. Narrowed it down to two amps now.
EV Q1212/Dynacord SL2400 And Dynacord L2800FP They perform almost identical at 8 and 4 ohm. And to my ears they sound the same on the SX300. List price is almost the same also. And as a fact, they are all on sale at this moment. Just around 700£ I dont need the DSP in the L2800FP, but its nice to have. I have heard good things about the EV Q and Dynacord SL. Not much to find about the Dynacord L. Maybe its still to fresh on the market ? What to do, what to do...
Crashpc
Registered User Joined: 26 February 2008 Location: Czech Republic Status: Offline Points: 463 |
Did not find anything about that amp.
FOO
https://www.production-partner.de/test/dynacord-l3600fd-verstaerker-im-test/
This is the most i have found about it. But after a picture comparison, i am quite sure its the same Amp internals. Ev Q1212/Dynacord SL2400 Dynacord L3400FD (i know its not the L2800FD, but they look the same inside more or less) |
Crashpc
Oh, 2800FD, not 2800FP!
These are good amps, but based on the review, and also transformer size and amp weight, I would not go by their power output ratings. If only power alone was the parameter to compare, I would say that the T. Amp TA-2400 MK-X for fraction of the price can about match it.
FOO
Actually based on the test, the power ratings seems to be rather fine.
Not that its that important.. Regarding the T Amps. Its much easyer to rent out gear with a known name on it. That plays a large role here.
midas
Old Croc Joined: 27 October 2011 Location: Cumbria Status: Offline Points: 2117 |
I suspect anyone wanting a pa for speech is not going to know a huge amount about what is good and what's not.
Matrix xt2000 take some beating on mid tops. As do QSC plx. Just lately second hand amps seem to have gone up in price.
Old Croc Joined: 02 April 2004 Location: United States Status: Offline Points: 5172 |
Dynacord has always been looked upon as Electro-voice in Europe. This has been the case for around 50 years. So it is like comparing identical twins in their products. Best Regards, |
FOO
I know. Thats why Q1212 and SL2400 is mentioned at the same time.
I am trying to decide between these two, and the L2800FD.
Buy the brand that has the most abundance in your area. This will keep everything looking uniform if you decide to buy more later on. Best Regards,
FOO
Thats the problem. Thats All LAB FP+ and PLM here. Waaay to expensive and powerfull stuff for the kind of jobs these setups will encounter :)
Im just wondering why the SL and L cost nearly the same. Its the same Amp inside, more or less. Only the DSP makes a difference. So i would expect the L to cost more.
What I meant was, between the Electro-voice and Dynacord, pick the one that is more in abundance in your area. The majority wants on-board DSP these days and manufacturers are capitalizing on those who want it. If you already have an LMS there is no need to buy an amplifier with an on-board DSP. If you are intrigued with on-board DSP in the amplifier and, have an LMS, compare the features of your LMS to the on-board DSP features in the amplifier. This will allow you to determine if the on-board DSP is a direct replacement to your LMS or you will lose some vital features you've grown accustomed to using your LMS. Best Regards, |
