Amplifiers Rescue Gods |
Page <1 23456 27> |
Lucasdude ![]() Young Croc ![]() Joined: 16 March 2013 Location: London Status: Offline Points: 578 |
Ah, Tobysound. That takes me back. Didn't they buy a ton of Wharfedale Diamonds with their own badge on?
EmPro ![]() Registered User ![]() ![]() Joined: 26 June 2020 Status: Offline Points: 281 |
Power Acoustics APK 2240
Output: 2x230w rms 4r Output devices 2x MJ15001 and 2x MJ15002 per ch Faults: broken psu capacitors from the main board,cold solderings,so new samwha caps fitted,new thermal paste on all outputs and drivers,and remade all the solderings,the amp is working flawless since:
Edited by EmPro - 30 May 2022 at 3:50pm |
EmPro Audio
Poor Crest Audio P4000 comes with right ch proper blown up,all the 12 outputs 2SB and 2SD,both drivers,predrivers,emitter resistors,bias diodes,op-amp etc etc
![]() ![]() Edited by EmPro - 28 May 2022 at 5:08pm |
EmPro Audio
Earplug ![]() Old Croc ![]() Joined: 03 January 2012 Location: Europe Status: Offline Points: 6948 |
I am just wondering if all these (wonderful) old amps are old projects, now done & gone - or stuff you still have lying around? And if the latter, how much room do you have in your house for anything else - like furniture - or clothes, etc! ![]() ![]() ![]() |
Well....this 3x4m room now is full.... ![]() ![]() ![]() Edited by EmPro - 28 May 2022 at 3:54pm |
EmPro Audio
EmPro Audio
EmPro Audio
Studiomaster Powerhouse Horizon 1208
2X600w rms 4r Fault: The dsp screen shows: Left Ch Overheating Turns out the fault has gone after i resolder all the output boards (4 of them) as i din't find any blown parts or dirt in the ventilation tunnel,the fan was working as it should,still own this one
![]() Edited by EmPro - 28 May 2022 at 5:27pm |
EmPro Audio
woody2 ![]() Old Croc ![]() Joined: 04 March 2010 Status: Offline Points: 1691 |
They look like the units MAM used. |
EmPro Audio
I like everything about this post. From the name that sounds like a 60s British car to the unnessecary filling of empty slots. Man's got his Partridge on!
Adding an extra 14amp per ch is not quite unnecessary when you play flat in low impedances mate
EmPro Audio
Page <1 23456 27> |
