Amplifiers Rescue Gods |
Page <1 878889 |
Earplug
Joined: 03 January 2012 Location: Europe Status: Offline Points: 7752 |
Posted: 19 October 2025 at 6:49pm |
The O/P stage has bipolar mixed with MOSFET? Never seen that before. How does that work?? |
EmPro
Posted: 19 October 2025 at 6:52pm |
EmPro Audio
Earplug
Posted: 20 October 2025 at 7:56am |
Aaaah. ok. That seems to be a waste of those Hitachis!! ![]() |
EmPro
Posted: 20 October 2025 at 8:03am |
Indeed it is
they used hitachi to drive the MJ5003's and also as a thermal limiter,when negative coeficient goes on and you push the amp hard the hitachi will slowly cut the drive as they heat :) that module doesn't have any other thermal tracking,just a output cutoff in case the temp goes well beyond 90c,the other ch has normal thermal tracking :)
EmPro Audio
cravings
Joined: 30 January 2007 Location: Ireland Status: Offline Points: 7508 |
Posted: 20 October 2025 at 9:41am |
looks like it has a lot in common with the bkelec stuff
EmPro
Posted: 29 January 2026 at 6:54pm |
DAP Audio QI 4600 smps blown in big style...all four IGBT's (G40N60),the gate driver(IR2113S),the mosfet IRF840 from low supply,both dropping zenners,the 12v stabilizer transistor,another B1 smd transistor (BC846),NTC blown in half and that will be all,after all these parts replaced the amp works again flawless
no damage taken in power amp section!!Edited by EmPro - 29 January 2026 at 7:10pm |
EmPro Audio
EmPro
Posted: 29 January 2026 at 7:02pm |
Not the cleverest idea to put weak igbt's in parallel in half bridge designs,so now the amp have only two igbt's but way way better and stronger with perfect matching: IRGP4066
tested one ch at the time in stereo mode will happily push 1.000w rms sinwave in 8R at 40hz! Not the cleanest sinwave i've seen but this is D class and at that power and frequency...i'm more than happy with the results from a 1U 6kg toy amp.
Edited by EmPro - 29 January 2026 at 7:21pm |
EmPro Audio
shaun1264
Joined: 06 September 2013 Location: Surrey Status: Offline Points: 325 |
Posted: 17 February 2026 at 6:25pm |
Another Carlsbro CP1000 Mosfet/HH VX900. I think these were built when Carlsbro owned HH. This one had DC at the output when gains were increased rising to 14V! Some people would have thought it was just noisy pots when they hear the pop/crackles and then blown drivers. I straight away suspected a 15v rail for opamps leaking in somewhere.. Disconnected input board at ribbon connector and DC offset vanished. Examined input board and found blown tracks. This could happen if the ribbon cable isn’t seated correctly i.e. too far over or some sort of high voltage shoved up the rear! There is full rail voltage around 80v going through this cable on some of the pins.. Anyway, re-built input board. Opamps and diodes tested fine. Problem solved. Next main board needed refurbishment. Caps drifting and high esr. Changed caps. Input DC blocking cap and feedback caps changed to higher value for a lower phase shift at bass frequencies. In the output blocks there are caps that also need to be changed. These caps live in a heated environment. Next a bit of experimenting: input low pass filter caps changed to a higher value. 220pf was used to reduce RF coming in. opamp feedback loop comp cap was increased in size which resulted in 20khz being around 1db down. (This is fine for me). I also increased miller cap slightly in value and lead comp cap. Yes, this will reduce slew rate limit figures but resulted in a very smooth and powerful amplifier. Square wave testing with various small capacitive loads and no oscillation. I don’t recommend fiddling with feedback comp caps unless you know what you are doing. Oscillation can easily occur blowing amps. There are too many amps where in the mistaken notion of chasing the lowest possible distortion at high frequencies, the final result is more often than not a marginally stable amplifier that breaks into oscillation, or rings, with real world loads. Very stable amps with good phase margin sounds sooo much better. ![]() ![]() ![]() ![]() |
EmPro
Posted: 17 February 2026 at 6:33pm |
VX series were poorly made compared to V or M series.....however i have some HH M900's with NE5532 opamp fitted and adjustabile input sensivity for each ch!! Not something you'll find normaly in these series
Great Job with that Carlsbro (VX900)
EmPro Audio
Page <1 878889 |
