  New Posts New Posts RSS Feed - Amplifiers Rescue Gods
 Post Reply Post Reply Page  <1 1314151617 71>
EmPro View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EmPro Quote  Post ReplyReply Direct Link To This Post Posted: 11 June 2022 at 11:44am
Well...fake as hell....good for 20-30w maximum...not even close to 2N3773 specs
EmPro Audio
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbl_man Quote  Post ReplyReply Direct Link To This Post Posted: 11 June 2022 at 1:08pm
Surprising that one, they look old and well-used, date code is 1996, maybe were mis-labeled as 3773, or maybe seconds?
I did a search for TSL (manufacturer? That nobody seems to have heard of)....opinions seem to be they aren't 3773's but are re-labeled lower spec devices, like 2n3055's etc.
Here is the link.
https://www.diyaudio.com/community/threads/tsl-transistors-2n3773-any-good-or-more-fakes.364152/
This is interesting reading.
https://sound-au.com/counterfeit.htm
Look at the MJ15003 link, is some real shockers on that. LOL
https://sound-au.com/fake/counterfeit-p1.htm
Edited by jbl_man - 11 June 2022 at 1:52pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote EmPro Quote  Post ReplyReply Direct Link To This Post Posted: 11 June 2022 at 2:04pm
That was the main reason i bought them in first place,looks old an used,and yes,the date code indicates 1996,but as you can see are proper fakes...more like 2n3055...but fakes as well LOLLOL i've seen that post but after i discovered myself that are ordinary fakes,and this ,,TSL'' ,,brand''  doesn't exist at all.
Yeah...that MJ15003 dual dies looks awesome...they spend more time and materials to make that fake MJ15003 that it takes to make a genuine one LOLLOL
Edited by EmPro - 11 June 2022 at 2:35pm
EmPro Audio
Post Options Post Options   Thanks (0) Thanks(0)   Quote EmPro Quote  Post ReplyReply Direct Link To This Post Posted: 11 June 2022 at 3:35pm
Bloody fakes all over the place...never seen these hitachi's being faked...but now...yeah...even the obsolete 2SJ50 and 2SK135 have clones listed as originals ofcourse...i own more then 20+ amps with these output devices,more then 200 passed thru my hands and not even one had written HITACHI on it,just the Hitachi logo and type of the mosfet,like in the first photo.
Edited by EmPro - 11 June 2022 at 5:28pm
EmPro Audio
shaun1264 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shaun1264 Quote  Post ReplyReply Direct Link To This Post Posted: 11 June 2022 at 6:21pm
Another Crown Micro-Tech 1200 with a early version main board at 1Khz running just before distortion creeps up because of clipping. 0.0091 THD (and stable at that too) I have to keep checking as it's a very low figure. This was after adjusting bias to 320mV on high and low sides, checking and adjusting ODEP voltages and adjusting Common Mode Rejection. I was getting 315watts in 8ohms (International model). The second channel was also very similar. I'm impressed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shaun1264 Quote  Post ReplyReply Direct Link To This Post Posted: 11 June 2022 at 6:30pm
Crown Macro Reference as new.
Post Options Post Options   Thanks (0) Thanks(0)   Quote EmPro Quote  Post ReplyReply Direct Link To This Post Posted: 11 June 2022 at 7:37pm
You don't need to be impressed by the MT series mate,this are proper overengineered amplifiers,you just need to adjust them,clean them,make the solderings again and you have proper bulletproof amplifiers for life,that Macro Reference is a beast...as i was saying before....deep bass = loads of silica dies on heatsinks and proper psu....now i've seen it.ClapClap
Mmmm funny i must say,i never adjusted the ODEP voltages on any of my MT-s so far,just the bias as it was way off on all of them,however never had any problem with odep so far,how was the ODEP on yours mate?
Edited by EmPro - 11 June 2022 at 7:44pm
EmPro Audio
Post Options Post Options   Thanks (0) Thanks(0)   Quote EmPro Quote  Post ReplyReply Direct Link To This Post Posted: 11 June 2022 at 7:51pm
I think this MT1200 had a hard life as i'm pretty sure crown didn't fit those parallel resistors there ConfusedConfused i've seen those resistors blown in a Macrotech 1200 that had a faulty in the driver board as far as i recall,the resistors gave up to save the outputs,the fault was couple of TO92 transistors next to the input sensitivity three way switch.
Edited by EmPro - 11 June 2022 at 8:00pm
EmPro Audio
Randy Bohannon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randy Bohannon Quote  Post ReplyReply Direct Link To This Post Posted: 12 June 2022 at 5:58am
That Macro reference is a gorgeous amplifier, just look at all that space inside for non-custom, not ruinously expensive,  replacement main filter capacitors… :D
Post Options Post Options   Thanks (0) Thanks(0)   Quote EmPro Quote  Post ReplyReply Direct Link To This Post Posted: 16 June 2022 at 11:12am
Guys what brand is this?? i found just one time 2SC5200 and 2SA1943 in one amp with this brand and there proper devices,quality build and proper specs,but cannot find nothing about this ,,three arrows'' brand Confused
Edited by EmPro - 16 June 2022 at 3:57pm
EmPro Audio
Post Options Post Options   Thanks (0) Thanks(0)   Quote kedwardsleisure Quote  Post ReplyReply Direct Link To This Post Posted: 16 June 2022 at 1:05pm
semelab
North Staffordshire
Post Options Post Options   Thanks (0) Thanks(0)   Quote EmPro Quote  Post ReplyReply Direct Link To This Post Posted: 16 June 2022 at 2:39pm
Originally posted by kedwardsleisure kedwardsleisure wrote:
semelab
Cheers mate,i didn't know semelab used this Logo,all my semelab devices are just marked: SML Confused
EmPro Audio
