Amplifiers Rescue Gods |
Page <1 1516171819> |
Author | |||
EmPro ![]() Registered User ![]() ![]() Joined: 26 June 2020 Status: Offline Points: 229 |
You will blow the amplifier useing it without a fan...he will heat and limit the outputs transistors always and this will make them weeker and weeker untill will blow up...the MT1200 is not made to be used without a proper cooling fan,as the heatsinks in these series are a joke compared to other amplifiers and are fully dependent of the fan air flow to get cooled properly.
![]() ![]() ![]() Edited by EmPro - 01 July 2022 at 3:38pm |
EmPro Audio
shaun1264 ![]() Registered User ![]() ![]() Joined: 06 September 2013 Location: Surrey Status: Offline Points: 224 |
As I've already mentioned I'll be putting a fan in.
Perfect :D but...where you planning to put it? as his space now is full with that transformer
EmPro Audio
When driver boards blows up on Citronic Conquest V12:
I made this immortal lateral mosfet amplifier two years ago...still going strong and for sure i will die old and this amp will still play no problem
![]() ![]() ![]() ![]() ![]() Edited by EmPro - 01 July 2022 at 5:26pm |
EmPro Audio
EmPro Audio
djkeet ![]() Registered User ![]() ![]() Joined: 26 December 2011 Location: England Status: Offline Points: 458 |
I like how the case turned out did powder coat it or what spray did you use? |
Soundbite
Black spray for cars mate :) from B&Q.
Edited by EmPro - 20 July 2022 at 7:13am |
EmPro Audio
Soundbite
Cheers
EmPro Audio
Seca23 ![]() New Member ![]() ![]() Joined: 08 September 2022 Location: Romania Status: Offline Points: 3 |
Hi!
I need some help with a HH Vx1200 amp Both the clip lights stay on, one gets a little dimmer after a few seconds after turning it on. I already changed the lm339n comparator but it made no difference The amp is working ok, it doesn't sound distorted at all. Another problem is when i turn it off it makes a squeaky noise for a few seconds on both channels. These problems apeared suddenly, it was working perfectly before. I would also like to know the procedure for adjusting bias and dc offset Thank you!
That is a common problem caused by leaky or dryed capacitors in driver board,always replace them with new ones and your problem will dissapear 100%,for bias and dc adjustments you should have trimmers (2 for each ch) with reference points for bias values
EmPro Audio
I can't find the test points and I don't know the corect value for bias
