  New Posts New Posts RSS Feed - Amps and drivers
Amps and drivers
Alimon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alimon Quote  Post ReplyReply Direct Link To This Post Topic: Amps and drivers
    Posted: 08 June 2010 at 9:43pm
been looking for 8ohm drivers for agers so i can run 2 a side on a matrix xp3000 but its finding impossible just wondering if i did the same with 4ohm drivers would it take the drivers down to 2ohms and be more risky on blowing the drivers or get any other problems?
cheers
Ali
Digga soundz
Saul View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Saul Quote  Post ReplyReply Direct Link To This Post Posted: 08 June 2010 at 10:58pm
which cab are you on about?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alimon Quote  Post ReplyReply Direct Link To This Post Posted: 09 June 2010 at 7:53pm
punisher v2 cab
darkmatter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darkmatter Quote  Post ReplyReply Direct Link To This Post Posted: 10 June 2010 at 4:36pm
Bump this thread, I'm sure someone will be able to get hold of them:
http://forum.speakerplans.com/topic34059_post341339.html
But yes, by using 2 x 4ohm drivers in parallel you would take it down to just over 2ohms (impedance is slightly higher in the cab as the horn adds impedance). By running 2ohms rather than 4ohms the amp would put out more power, you'd lose damping factor etc. I'd imagine 8ohm drivers would be preferable.
