Amps for PD1850 |
Page 12> |
sam012 ![]() Registered User ![]() Joined: 06 June 2022 Location: UK Status: Offline Points: 19 |
![]() ![]() ![]() ![]() ![]() Posted: 06 June 2022 at 10:04pm |
I'm planning on building a hobby rig this year - i've been lurking here for years on and off and finally making the plunge into building something decent
Starting with 4 scoops & 4 hd15 on the low end Drivers will be pd.1850 + probably pd.154 Are there any go-to amp setups for the subs above? It's quite daunting searching multiple brands online with no real experience in working with amps before I was going to go ahead and buy 2 Proline 3000, but reading loads about clipping and being a noob i'd rather buy decent gear that I can setup properly to run the rig safely Budget isn't that of a commercial sound system, I reckon about £1000-£2000 on amps?
Edited by sam012 - 06 June 2022 at 10:06pm |
al_x ![]() Young Croc ![]() Joined: 12 February 2006 Status: Offline Points: 829 |
I would recommend CVR amps. We have the 3302 and it’s just awesome. Cost around £720 inc shipping. The D1504 would power everything you have listed in one amp.
Or go for a void infinite 8 for bass if you want an old heavyweight. |
Thanks for the recommendation👍, how do you buy them? Googled and can’t find anywhere
Sinai Sound ![]() Young Croc ![]() ![]() Joined: 09 November 2009 Location: Sheffield Status: Offline Points: 627 |
2nd hand Void Infinite 8 v2 would be my shout
paulus ![]() Old Croc ![]() ![]() Joined: 14 December 2005 Location: SOUTH BIRMINGHA Status: Offline Points: 3164 |
also if you can find one the sae pxm 1450 , 2300w per chann at 4 ohm @ 40hz , and very efficent omn a 13 amp feed i have been running 4x 1850s on mine for a few years now 0 issues sometimes run 6 as well and again been fine runs cool to
TRENDSETTER SOUND SYSTEM
levyte357- ![]() Old Croc ![]() ![]() Joined: 27 July 2012 Location: UK, South East Status: Offline Points: 8076 |
If using pd1850s, would not recommend Standard Super Scooper 18, look for the Mykey 18" Fane design here.
Void 8MK2 might be hard to find/out of your budget, Crown MA5000VZ or Crest CA18 are go to choices, CVR would be a risk in my books. Paulus is happy with hIs SAE 1450. Personally don't rate HD15s, ES18s are far superior, I prefer the Electrikal 636x636 version.
Edited by levyte357- - 07 June 2022 at 3:18pm |
yes mega points for the SAE at 4 ohm ,stamps on the vz5 and ca18 on 13 and 32 amp feed very nice sounding amp . will run 1850s to there limits without clipping( just ) , the ca18 and crown will be full tilt , i have owned all 3 act all 4 also had a void super powerful but i just didn't like the sound of it and again on 13 amp being a class H not to efficient :)
Edited by paulus - 07 June 2022 at 3:40pm |
But I'm hearing, you cannot get these new right, and needs to be the "original" version, is that this one !? ![]() |
The quote on the build is with 4 hogs 😁
Also, is google the best way to find pre owned gear? This industry is a nightmare to buy anything in! What kind of money would a infinite 8 be second hand?
Edited by sam012 - 07 June 2022 at 6:14pm |
dnbpc ![]() Registered User ![]() ![]() Joined: 18 March 2010 Location: Manchester Status: Offline Points: 361 |
May have 4 PD1851 loaded hogs for sale soon if you want to save on a fresh build?
Edited by dnbpc - 08 June 2022 at 9:22am |
Pick & Mix Soundsystem
4D ![]() Old Croc ![]() Joined: 13 November 2008 Location: Winchester Status: Online Points: 4242 |
LMC audio have new old stock boxed Crown VZ5000's listed @ £1700.00 each.. Should last a good twenty or not thirty years or more
Page 12> |
