  New Posts New Posts RSS Feed - Amps/x-over/... for new soundsystem
KMB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KMB Quote  Post ReplyReply Direct Link To This Post Topic: Amps/x-over/... for new soundsystem
    Posted: 20 August 2018 at 1:55pm
Hello,
I’m building a soundsystem and have some questions.
This is my idea/plan (2 scoops to start with):
- 2x Scoops 18”
- 1x USB Bin 18” (2 drivers)
- 2x MT121
- Tweeterbox (if necessary)
I have already build a superscooper with:
RCF LF18X401
1500 W AES
8 Ohm
And works fine on amp mentioned here below.
I bought the T-Amp TSA 4-1300 a year ago because of the amount of power it can give for the price.
Happy about the product, but had to send it back for warranty because it was broken after some months.
T-Amp TSA 4-1300
4 x 1670 W / 4 ohm
4 x 1220 W / 8 ohm
2 x 4000 W / 8 ohm
So here are my questions:
1. What can I do with the TSA 4-1300? For scoops? or for mid/high section?
2. What other amp's should I buy for my soundsystem? And a Limiter?
3. What crossover freqencies should I use?
    I prefer loud, agressive but clean sound/bass
    Current x-overs 4way mono: 92hz-250hz-4.1kHz
4. How much watt does the channel of the amp must have for a 1500w AES driver like mine for ex.
5. I have read somewhere that two 8 Ohm drivers together can play on 4 Ohm amplifier? Is this correct and usefull (sound compared to 8 Ohm)?
My budget: Moderate (not cheap, not too expensive)
Genre: Dub/Stepper/Roots
Please give me your advice, what to do or to change.
Bless
Edited by KMB - 20 August 2018 at 2:16pm
You'll get the message trough the bassline
mini-mad View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mini-mad Quote  Post ReplyReply Direct Link To This Post Posted: 20 August 2018 at 4:17pm
Few minor things...
The 4-1300 isn't a good scoop amp. Even BRIDGED. So a different amp will be required for sub duty. The 4-1300 Will be great for kicks upwards.
Also you mention you like CLEAN bass, scoops colour the sub a LOT! They don't produce clean sub. The hog has a cleaner sound... but then again most dub systems don't want clean sub.
And in this case for the scoop amp I would aim for something with head room so the amp doesn't run super hot all night long. The idea of headroom is not to wack MORE power into the driver it's to make sure you're not running the amp close to clip and sweating the amp til it dies.
KMB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KMB Quote  Post ReplyReply Direct Link To This Post Posted: 21 August 2018 at 8:15am
Hello, thanks.
Do you have some recommended brands for sub amplifiers?
callumtruds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote callumtruds Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2019 at 9:19pm
Suitable Bass amps for 4 scoops
Matrix 10k
PKN xe10000
Mc2 e90
Ffa 10k
Powersoft k10
Infinate 8
Ca18
Mid & tops
4-1300 (cheap option)
Any suitably sized
PKN
Matrix
Powersoft
Sae
Crest
Mc2
FFa
Processing
Xta
Xilica
DB mark
Dcx 2496 (cheap option)
Read about wiring speakers in series
You want 4-6mm2 thickness cables for sub
Edited by callumtruds - 26 May 2019 at 9:22pm
king david View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote king david Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2019 at 9:16pm
look for Qsc, to add to the list above
Edited by king david - 28 May 2019 at 9:18pm
