amps! |
GrinGrin
Registered User Joined: 27 February 2020 Location: chichester Status: Offline Points: 15 |
Posted: 03 July 2020 at 7:58pm |
halloo, im pretty new to this and have just bought myself 2 ES-18's loaded with P-Audio 800's, -http://p-audio.co.uk/pdf/E_18ELF.pdf I believe there the ones. alongside I got a Behringer EP4000 power amp and Im not entirely sure what settings to have it on to prevent blowing the drivers
this is what Behringer have to say about the product:
njw
Thanks(1)
The actual rms power ratings for that amp I think are actually 450/750/1200w per channel into 8, 4 and 2ohms and 1500 and 2400w into 8 and 4 ohm bridge. I would wire the cabs in parallel for a 4 ohm load and then run the amp in bridge mode. As long as the amp is kept out of clip you won't damage anything and get the most SPL from your cabs.
