And so it begins... with build pics! |
Page <12345 12> |
Heathrow_B_line
Joined: 11 January 2006 Location: United Kingdom Status: Offline Points: 7339 |
Posted: 02 May 2006 at 7:27pm |
Mark James
Joined: 15 January 2006 Location: rig side Status: Offline Points: 5306 |
Posted: 02 May 2006 at 7:28pm |
imho the best stands for mid top speakers in the world has to be..........................................
a phat stack of bass bins! a helluvalot better [in my opinion and prolly my opinion only!] than any tripod quadpod or zillionopod [dont exist i know but hey] |
insert silly sentence here
Fushion Julz
Posted: 03 May 2006 at 5:14am |
Never quite sure why people want to change the design to make the 2
mids together with the top on top...Surely the advantage of the
original design is that you avoid most of the combing problems by
seperating the mids and the cab works as a line source having the
drivers in the original configuration...
Single 12" cabs have the advantage you can array them in a side-by-side configuration to acheive more dispersion, but you won't need one compression driver for each 12" mid!! Even the 2-1 ratio in the original design is a bit top-heavy using CP800Ti for the tops. |
Mark James
Posted: 03 May 2006 at 5:37am |
so are the plans wrong then?
Fushion Julz
Posted: 03 May 2006 at 5:45am |
Actually, when I made mine, I cut the horn flares to match/fit the
*actual* fitting...starting with the top/bottom screwed to one outer
side panel and with the lines for the side parts of the flares drawn on
the top and bottom of those flares...
The original cut I made (from the plans) didn't fit and I came up with that way as the easier (and quicker) method rather than trying to work it all out in Autocad, or similar, and STILL getting it wrong in practice.. Once I'd done the first one, I just copied another 3 times and it all went together pretty well! |
Mark James
Posted: 03 May 2006 at 7:03am |
i think james used a similar methode.
Heathrow_B_line
Posted: 03 May 2006 at 1:56pm |
dont know about quicker.... it only took me 40mins to draw it in cad, probably would have taken me just as long to mark it all out and then realise i messed it up... 2d cad can only get u so far though, i think with 3d cad u can create a model that u can prove to urself is correct. the plans arent incorrect, its just to get the flares at 12 degrees and 24 degrees there slightly off from where they should meeet. i like the mt121 design as its just a handy dinky thing rather then the full on mt122. i wouldnt mind changing the high freq horn...any suggestions? i agree that the stacked 12 mids are silly but they look funky u have to admit! i was thinking about maybe doing something like the turbo sound cabs and join a mt121 with a hd15 and see how that looked.... mite build a pair just for fun! |
Men@work
Joined: 17 November 2005 Location: Great Britain Status: Offline Points: 89 |
Posted: 03 May 2006 at 5:50pm |
At the end of the day its gets dark!! THEN WE PARTY
Heathrow_B_line
Posted: 03 May 2006 at 6:36pm |
i just found some in a local hardware store for £3 each... i bought 6! like u do!
Dom
Joined: 25 February 2004 Location: United Kingdom Status: Offline Points: 1700 |
Posted: 09 May 2006 at 8:08pm |
MT122s are not dinky. They are backbreaking...
I am really interested in getting some of those angle clamps... Do they have a name, manufacturer etc??? |
Heathrow_B_line
Posted: 10 May 2006 at 3:21am |
I never said they were.... i've found them clamps on the net, i'll post a link when i get a chance... £4 though! |
Heathrow_B_line
Posted: 11 May 2006 at 6:28pm |
i think i have a clamp fetish.... i keep buying the f**kers. ive got f-clamps, g clamps, those corner ribbon clamps, mitre clamps, carpenters clamps/spreaders, saw guide clamps.... and i always seem to buy in quanities of 2 or 4. i need to join a support group i think! |
Page <12345 12> |
