  New Posts New Posts RSS Feed - Angles for 186...
Angles for 186...
wusabi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wusabi Quote  Post ReplyReply Direct Link To This Post Topic: Angles for 186...
    Posted: 15 May 2006 at 3:46pm
Could someone please tell me the angles for this cabinet, some posts have said that they are the same as the 1850 but they surely can't be the same, as the 1850 has a larger rear chamber for the bigger driver...
Could anyone help me on this...?
gingerbiscuit69 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gingerbiscuit69 Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2006 at 7:13am
driver same size pretty much. learn some basic maths (GCSE stuff - use some bitesize revision if ure a dropout) and using very basic maths they are easy to work out.
even easier than that, just take one side and draw the measurments on like the plan and build it that way. I tend to work stuff out as i go, just check it before cutting/attaching and u will be fine.
good luck, P
