  New Posts New Posts RSS Feed - another cardioid question
teeth View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote teeth Quote  Post ReplyReply Direct Link To This Post Topic: another cardioid question
    Posted: 16 February 2023 at 10:14am
hi, i'm just about to have enough subs in my arsenal to give proper cardioid stuff a go.
rear sub located 1/4 wavelength behind the front sub(s) (0.8 m)
rear sub  delayed 1/4 wavelength (2.3 ms)
rear sub polarity reversed
i'm wondering how acoustically similar the cabs have to be to get the desired response, my understanding is to do it "exactly" they have to be identical, but if they are similar enough the effect will still be there, just less pronounced.
the cabs in question are WS218X copies. 4 are identical and loaded identically (b&c), 2 (reversed) are close enough, but loaded with different drivers (RCF).
to add further deviation, i don't have a unified amp set up for my bass section - each pair is run off a different amp.
i'm not after a perfect set up here, just a good enough effect so as to reduce SPL to the rear due to noise concerns. your thoughts and experience appreciated.
Edited by teeth - 16 February 2023 at 10:19am
csg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote csg Quote  Post ReplyReply Direct Link To This Post Posted: 16 February 2023 at 11:10am
Dissimilar subs does not preclude use in a directional array but it would certainly be worthwhile measuring the two different subs for time/phase so you can correct for any differences. This may result in a change of placement or time correction.
In more general terms please remember that directional arrays are at times very useful but at other times they can cause as many problems as they solve, by way of increased overall energy exciting tent or venue surfaces causing greater, still omnidirectional leakage.
airbell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote airbell Quote  Post ReplyReply Direct Link To This Post Posted: 21 February 2023 at 7:56am
After testing a lot in my opinion it is in general always better to use the same subs and amps instead of mixing different ones, even if the phase and frequency response look more or less the same!
But if you have the same enclosure with the same tuning and only different drivers but with similar thiele small parameters it should work fine together and so cardioid should work too.
As csg wrote, is always better to measure than only to calculate the delay, and take care that you have enough distance from the subs to the microphone.
Edited by airbell - 21 February 2023 at 7:59am
