  New Posts New Posts RSS Feed - another drives for HD15
PoteirosCorp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PoteirosCorp Quote  Post ReplyReply Direct Link To This Post Topic: another drives for HD15
    Posted: 08 September 2004 at 3:53am
Hi! !
I was hopping you tell me if this driver could work on HD15
http://www.dasaudio.com/speakers/_files/hojastecnicas/te15lm -00.pdf    its the DAS 15LM  it has a EPB of 135
Why this??   because I already have 8 of these on 2x15 fullrange  and the bass sound good. Want to trade them to the HD15. Also is cheap here (around 60 dlrs)
I only need to reach 50hz or 63hz. Thinking on cutting the HD15 with the DAS on 350hz or something like that. Later Im gonna make 10" tops.
Thanks for your input
Paul Valenzuela        &n bsp; Hermosillo, Sonora, Mexico
P.S. Can you kill the Neet guy ??
JD01 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JD01 Quote  Post ReplyReply Direct Link To This Post Posted: 08 September 2004 at 6:01am
350Hz? Very unlikely. The HD15 will do 180-200Hz with a higher BL driver. Higher frequencies than that can be squeazed out by EQing and such but they won't sound that good at all....
Post Options Post Options   Thanks (0) Thanks(0)   Quote PoteirosCorp Quote  Post ReplyReply Direct Link To This Post Posted: 08 September 2004 at 6:24am
ok ok
so I cut at 200hz
still wondering if they can do de the 50hz  qith the DAS
thanks for the input
Andrew View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andrew Quote  Post ReplyReply Direct Link To This Post Posted: 08 September 2004 at 7:52am
I've taken the HD15 to 254Hz without any noticeable dip.  Wasn't exactly pushing them though.
JD01 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JD01 Quote  Post ReplyReply Direct Link To This Post Posted: 08 September 2004 at 4:41pm
@ Andrew: I guess you are only talking about frequency response. Some other factors will go down above 200Hz. That is a matter of taste then..... well, kinda at least.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andrew Quote  Post ReplyReply Direct Link To This Post Posted: 08 September 2004 at 4:48pm
Yes, the plot of the HD15 is a bit like a bell curve, but I found that they are pretty flat at gentle levels, and I only had to take a couple of dB out around 125Hz to get a flat plot on the spectrum analyser.
