Another nested basshorn design |
_djk_ ![]() Old Croc ![]() Joined: 23 November 2004 Location: United States Status: Offline Points: 6002 |
![]() ![]() ![]() ![]() ![]() Posted: 30 October 2007 at 1:48am |
This design has a large front cavity to eliminate the dip above Fc for a small horn mouth.
djk
By sectioning the cabinet at the line, and adding a hinge where shown, the cabinets will nest for hauling eight in a standard cargo van (4'x4'x8').
![]() Edited by _djk_ - 30 October 2007 at 8:10am |
djk
Fold out the wedge, and this is how they would set-up.
![]() Edited by _djk_ - 30 October 2007 at 1:52am |
djk
hifiger ![]() Registered User ![]() Joined: 17 October 2006 Location: Canada Status: Offline Points: 82 |
looks like a really space efficient design!
tommysb ![]() Registered User ![]() Joined: 24 April 2006 Location: Finland Status: Offline Points: 1036 |
that setup negates the need for a large rear chamber to compensate for the small mouth, the mouth looks decidedly large!
Disco Stu ![]() Old Croc ![]() Joined: 03 March 2005 Location: United Kingdom Status: Offline Points: 2487 |
My kind of horn - so thats a 40Hz horn length?
Only problem is the requirement for a plate over the mouth area
Stu
All you need to know is:
Sensitivity + Power Handling - Power Compression = Max Output My acts: www.myspace.com/thebowiexperience www.myspace.com/scheisseelektronisches |
Timber_MG ![]() Registered User ![]() ![]() Joined: 27 March 2004 Location: South Africa Status: Offline Points: 1454 |
Just stack enough that it no longer really matters :)
A 2x2 stack is about 8' tall, you won't get much more output with a top plate.
djk
mykey ![]() Old Croc ![]() Joined: 18 August 2005 Location: UK/Indonesia Status: Offline Points: 9680 |
Your gonna have to put a guard rail up to stop bass heads standing in them
![]() I'd like to hear these when they're done
![]() Edited by mykey - 01 November 2007 at 5:57am |
The basic design and drawings are by Bill Woods, a commercial horn designer with 30+ years experience.
My contribution is the nesting scheme.
djk
pgolde ![]() Registered User ![]() Joined: 06 September 2006 Location: United States Status: Offline Points: 17 |
What driver was this horn designed for?
pg
Kind of a 15" version of the Lab 12 driver. Fs in the low 20s, Vas over 10 cu ft, Qts 0.30~0.40, high x-max. The original driver was only about 92dB as a direct radiator, and came up to 100dB in the horn. One pair stacked would be about 105dB/2.83V/1M below 50hz. Four stacked as in the drawing ought to be close to 110dB/2.83V/1M.
The reason for posting it here was mainly conceptual. In practice I would adjust the back chamber and throat cavity for the driver under consideration, and probably simplify the corner reflectors.
djk
