Any Linea research 4/8 chan M series owners here? |
Matty309
Registered User Joined: 13 May 2019 Status: Offline Points: 116 |
Posted: 03 January 2021 at 2:31pm |
Hi,
Ive got myself a 4 channel Linea research a 44M20 amplifiers and its rated for 20KW continuous output ( 5Kw per channel into 2 ohm). Does anyone know if this would actually be suitable to run lets say 14 1KW subs off it? The power density of this amplifier seems too good to be true however it is class D so I wouldn't be surprised. Does anyone have experience with any of linea research Amplifiers? would be interested to chat about them. Thanks
Edited by Matty309 - 03 January 2021 at 2:31pm |
U.Viktor
Young Croc Joined: 04 May 2010 Status: Offline Points: 716 |
Even 2 channel amplifiers can not really do 5000W "continuous" on 2 Ohms (just more likely 2-3000Watts for few seconds..) There is absolutely non-exisitent category a 4ch amp with 4* 5000W real capability = when all channels are loaded with SUBS for example. When I tested Powersoft X4 (also called '4* 5K amp..) it worked only with very low duty cycles, speaker ways splitted accross its channels like one for 1. SUB another for 2. LOW and the 3. Middle and 4. HIGH.. Still it was somewhat 'affordable with some sacrifie of dynamics' with relative low duty cycle musics, dense signal on strong speakers would immedatly pull down the whole amp ! Yet not speakeing about ALL channels loaded by SUBs! :-D
Matty309
Thing is you say that but there's a video on youtube (Martin Audio - w8lm high cabinets - ws218x subwoofers - endfire - YouTube) with someone running two Martin audio (powersoft hardware) MA12k amps on 16 1KW drivers. and they're being driven HARD. These high end amps must do what they state otherwise they wouldn't have the reputation that they have?
Matty309
i am aware that music is dynamic but a lot of rap and EDM music especially drum and bass has basslines that basically dont stop.
csg
The power inlet is rated to 8Kw at 250V. Good as lineas are, they ain’t magic.
Nor do they claim to be, the 20Kw rating is with a good deal of dynamic range, as with all modern amplifiers. Good thing to, the dynamic headroom afforded by modern amps such as the lineas or powersofts are hugely beneficial to sound quality at high spl levels. Your amp will be able to drive a large number of subs and make a good deal of noise. Personally I would not recommend running any amplifier at 2R per channel as the bass will likely loose definition and the power supply of the amplifier will struggle. It will work and you won’t damage an amplifier built to that standard, but its far from ideal.
Matty309
So what would you personally run off the 44m20 to get the most out of it? For example its rated for 10KW at 4 ohm with 2 channels bridged. you think it would be safe to run 8 hogs off that? or would 6 be a better option?
U.Viktor
There are no miracles, the maximum duty cycle defined is 9dB crest factor with 3475W power inlet with 4600W apparent power due low power factor (likely NO PFC..). In case of very optimistic efficiency estimation with 90% the delivered charging power is 3130W distributed across four channels. They stated energy storage of 600 Joules. -3dB power drop is usually -30% in rail voltage > half of the total capacitor bank need to be calculated: 300 Joules It is adding 300W for 1 second +3000W for 0.1s +6000W for 0.05s (20Hz !) +30000W for 0.01s (100Hz) Please keep in mind that you need to deliver at least 1.41 * nominal rms power at the peaks so if you have 20KW you need to have storage for 29KW. So this amp maybe can deliver 4* 5000W pulses around 90Hz but not lower...
Edited by U.Viktor - 03 January 2021 at 5:10pm |
Matty309
Thanks for that detailed reply, i looked through this download myself. Linea state in there YouTube video that they can deliver 20KW for 1 seconds or more. Intro to Linea Research M & C Series Amplifiers - YouTube
Basically, what I'm trying to do here is get an estimate how much power i can realistically expect from this amplifier, Powersoft have similar output ratings to linea. I guess it highly depends what music your playing, a pure sine wave with crest factor of 3db is not going to be sustainable but a lot of bass heavy music does have long basslines for the entirety of the track.
kipman725
Registered User Joined: 02 September 2020 Location: Warrington Status: Offline Points: 231 |
There are amps that can sustain high sine wave power but they are not marketed at audio and are more expensive: It depends on the other amps you have but I would try to mix the subs with mids/highs so the stress on the power supply is reduced.
snowflake
Old Croc Joined: 29 December 2004 Location: Bristol Status: Offline Points: 3121 |
less than you might think. if you are producing music you will presumably be listening it on monitors powered by commercially available amplifiers and will soon learn that a bass sound with a higher level impact at the start and then a lower level sustain sounds louder and better. and all basslines must have some variation (duty cycle) or it fails the definition of being music. Someone did blow up some DJ monitors of mine within 30 seconds of plugging in once - after looking for a problem with the amplifier I found that the first tune they played was their own dubstep production with a 20Hz sinewave as the bassline.
Matty309
Thats a very good point actually. They say the Linea amp is rated for 20Kw for up to about a second so that would change your perception of how loud it really is if the initial hit is harder.
Haha typical , what a shame. Thanks for your input |
