Anybody have plans for the G-Sub but 15"? |
Post Reply | Page <123> |
djeddie
Which 15's did you use in the P-Audio cab Colin?
colint
Old Croc Joined: 06 October 2007 Location: United Kingdom Status: Offline Points: 5222 |
I used some old EV drivers worked a treat but I've since also tried them with some 2226H JBL's the result was really warm low bass and plenty of it, nice useful box if a bit large for a 2 x 15 but very usable as a simple four box system with the right top boxes.
Dub Specialist Sound
Thanks(1)
Yes great cabs tbh, i built these too worked well above my scoops cut at 70-85 there about so runn these to about 175 and thay hit hard man and move some serious air too, pd loaded
tested them with pd1550 deadly, and some eminence/fane xb and orther drivers with lighter cones big difference in upper-bass tones, ovisly depending on x/o points...lighter cones faster response...worked well tho in upper-bass range too really rate these cabs good cone controll too...as colin said a good all round bass cab tbh...agreed, brace them well too love them !!! Edited by Dub Specialist Sound - 03 March 2015 at 10:30pm |
Thanks(1)
C-Audiofreak
Registered User Joined: 12 June 2014 Location: Norfolk uk Status: Offline Points: 467 |
hi dub specialist please can you pm me the plans you used to build those cabs i cannot seem to copy and print the one posted here
no problem , done my friend....
C-Audiofreak
Cheers dub😃👍
TacticalSound
Registered User Joined: 25 June 2017 Location: Sweden Status: Offline Points: 17 |
if i can have it , i want this print to.. have been searching for them and dont find bless up
colint
insguy
New Member Joined: 16 September 2019 Status: Offline Points: 7 |
Greetings. Warming up this thread again as I am planning to build a "15" G-Sub" to go above two 18" Scoops. I am a novice at woodwork but succesfully managed to build two cabins for Mids and now am looking for the next challenge. I found two different versions for the "G-Sub" 15" design. One seems to follow the original Mogale plan: (compare the original 18" G-Sub here: http://www.speakerplans.com/index.php?id=gsub - https://www.speakerplans.com/index.php?id=gsub ) The other one is from P-Audio and I call it a "G-Sub" just for being very similar in desgin yet a lot more complex to build: The first seems pretty straightforward and easy to build, however all the discussion and experiences in this thread (especially from Dub Specialist) are regarding the more complex design. I am wondering if anyone has build the simple version and could even compare it to the other one. Also rearding both designs: I want to build in handles at the sides, does it matter where exactly they go? Can the space/volume they take up inside the cabin be ignored sound/tuning wise? Thanks for your replies!
Edited by insguy - 16 September 2019 at 6:53pm |
toastyghost
It’s a pretty basic reflex cabinet. You can easily simulate one for the driver of your choice and build it. Just brace the hell out of the panels.
Thanks(1)
Ive built 100s of boxs , p-audio will piss over standed plan 15in g-sub
