  New Posts New Posts RSS Feed - Anyone build the MT 122ís?
soundgodwannabe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote soundgodwannabe Quote  Post ReplyReply Direct Link To This Post Topic: Anyone build the MT 122ís?
    Posted: 23 January 2005 at 12:47pm
I can't seem to picture in my head what the MT 122's would look like. Has anyone built these and have pictures available?
Make the soundman mad and I WILL press the suck button for your band.
Fushion Julz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fushion Julz Quote  Post ReplyReply Direct Link To This Post Posted: 23 January 2005 at 2:12pm
FUSHION SOUNDSYSTEM
www.fushion.org.uk
Post Options Post Options   Thanks (0) Thanks(0)   Quote soundgodwannabe Quote  Post ReplyReply Direct Link To This Post Posted: 25 January 2005 at 12:27am
The picture really helps. I was thinking that there was a horn in the middle. I guess on could put a horn there if they wanted to. What I am wanting to do is stay in a three way system, with room for great female vocals and drum sound.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fushion Julz Quote  Post ReplyReply Direct Link To This Post Posted: 25 January 2005 at 6:49am
There is a horn in the middle....Only when I built them I had a seperate horn in another box...Since replaced by the correct Beyma CP800Ti and horn as originally suggested by Rog prior to P-Audio being "flavour of the month" (the mids are P-Audio SN12B, though)
FUSHION SOUNDSYSTEM
www.fushion.org.uk
moss View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote moss Quote  Post ReplyReply Direct Link To This Post Posted: 22 April 2005 at 1:10pm
julz, just followed your link, cool photies!! what are the cabinets that have red fronts/insides??
Edited by moss
spOnge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote spOnge Quote  Post ReplyReply Direct Link To This Post Posted: 21 November 2005 at 8:11am
lovely
james folkes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote james folkes Quote  Post ReplyReply Direct Link To This Post Posted: 09 December 2005 at 11:47am
them be a double variant of the selenium hb1505c1, as found by
navigating
through the constructions section of www.selenium.br, they are part of a
complete system called i think frento fundo.
http://www.selenium.com.br/site2000/trio_eletrico/pdfs/
Trio_Eletrico1.pdf
i was going to build 16 of them (they model nicely) but have opted to put
the drivers into a modified martin 215 mkIII instead because they are a
little more manageable and go lower with fewer boxes, on paper at any
rate...
james.
(as my text doesn't wrap i can't put big links like that as active, sorry!)
mardy hippy.
Bubba View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bubba Quote  Post ReplyReply Direct Link To This Post Posted: 09 December 2005 at 5:14pm
Hey Guys.
I am need to the completion of building my first MT122. Can one of you advise what kind of connection i can use in the back. Julz from your pictures i could not make out the connection.
soundguymark View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote soundguymark Quote  Post ReplyReply Direct Link To This Post Posted: 10 December 2005 at 4:43am
the best connectors to use and pretty much industry standard are neutrik Speakons.
Mark
Post Options Post Options   Thanks (0) Thanks(0)   Quote james folkes Quote  Post ReplyReply Direct Link To This Post Posted: 10 December 2005 at 5:44pm
seconded, don't waste your time with owt else.
james.
mardy hippy.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fushion Julz Quote  Post ReplyReply Direct Link To This Post Posted: 14 December 2005 at 6:54am
I used 4 speakon NL4s on each cabinet in 2 seperate plates...in/out for Hi and Mid
James: The Selenium cabs go quite low (around 35Hz) in 4s...but they work best from 80-220Hz...but they go higher, if necessary, too...
A great and versatile design...Just a bit big, is all!
FUSHION SOUNDSYSTEM
www.fushion.org.uk
Post Options Post Options   Thanks (0) Thanks(0)   Quote james folkes Quote  Post ReplyReply Direct Link To This Post Posted: 20 January 2006 at 3:28am
oh don't say that! i had really set myself on making a gigantic pile of them,
hornresp had shown that stacks of 8 a side had the potential for some
serious comedy. they are quite big though, ultimately when i worked out
that the martin bins were quite a bit more compact and seeing as how
transport space is at such a premium i thought i knew which way to go.
i have to face the fact that my martins might not happily cross to the 10"
mt122 variants though, my mkI bins may have given me a false sense of
security as the almost straight horn allows crossing above 250Hz with
seemingly little ill effect.
james.
mardy hippy.
