anyone know what drivers the Turbo TXD 12m uses? |
solution
Young Croc Joined: 26 June 2005 Status: Offline Points: 767 |
Posted: 08 August 2007 at 12:05pm |
I would'nt mind trying to build a pair, all the dimensions are on the turbosound website...so does anyone know what drivers they use and if they are available as driver only???
Bassmentality: Ska, reggae, funk & Hip hop every month @ The Cellar, Oxford
j_0_e
Young Croc Joined: 18 March 2007 Status: Offline Points: 659 |
i was looking at building some of these too...
solution
yeah should'nt be too hard you can get the dimensions and angles on the wedge fornm the turbo site but I'm not sure what drivers they use, I know turbo often spec off the shelf drivers such as PD, beyma etc but then they also have thier OEM ones as well....so if anyone can shed any light on it or even recomend some drivers for the box dimensions that would be great
ceharden
I'd make a guess that it's a PDN 12MH25 given that they use the 15" PD neo drivers in their larger wedges. Unfortunately they are not easily available at the moment. I'd suggest buying the B&C 12NDL76's that Smokey Joe is selling, they're an excellent driver for small wedges.
As for the top end, something like a B&C DE160/250 etc would be great. I recommend B&C because they're the drivers I know best. There are alternatives if you prefer other manufacturers. P-Audio SN12MB + SN-D44/BM-D450 for example for a budget version. |
solution
cool might have a look into that then...have to wait for some other bits to come first but I'd like four of those to finish the set up off. cheers for the advice ceharden
Dom
Old Croc Joined: 25 February 2004 Location: United Kingdom Status: Offline Points: 1700 |
Turbosound list all their components in a "component map" file which is somewhere on the website.
It uses an LS1219 woofer and a CD111 compression driver with a PX121/X crossover.
You can normally buy all Turbo parts seperately - they know how to charge though...
solution
I take it those are the turbo model numbers...will these drivers be bespoke turbo only drivers or are they literally rebadged PD etc and I can find out what the off the shelf models are...don't really want to pay bucks for the turbo badged stuff i can get it cheaper...might as well buy the cabs otherwise cos I'm still paying for the badge on the front if i buy drivers from them.
