  New Posts New Posts RSS Feed - Anyone Remember These?
AJ AUDIO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ AUDIO Quote  Post ReplyReply Direct Link To This Post Posted: 01 April 2020 at 2:08pm
AL250 From BI PAK 125W RMS into 4 ohms
single supply 50v to 80v
Quasi Baxandall output stage using 4 2N3055s
Big output coupling capacitor required
Repaired quite a few of these, I still have the circuit diagram, I believe I might have the remains of a PCB for one of these
Robbo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robbo Quote  Post ReplyReply Direct Link To This Post Posted: 01 April 2020 at 2:16pm
They also look a fair bit like the old Tuac modules to me.
100 Volt-line View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 100 Volt-line Quote  Post ReplyReply Direct Link To This Post Posted: 01 April 2020 at 2:36pm
I remember some similar modules called Klifco, I think.
BJtheDJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BJtheDJ Quote  Post ReplyReply Direct Link To This Post Posted: 01 April 2020 at 2:59pm
+1  Tongue
I still have most of it left.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Earplug Quote  Post ReplyReply Direct Link To This Post Posted: 01 April 2020 at 3:08pm
Ok - this thread feels like it´s from an age ago! Sign of the times, I guess. How quickly everything has changed over here.  Ouch
And like so many things, this project got put on the back-burner and awaiting better times, if they ever come, but thanks for the info.  Thumbs Up
Edited by Earplug - 01 April 2020 at 3:11pm
geez View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote geez Quote  Post ReplyReply Direct Link To This Post Posted: 22 November 2022 at 12:07pm
Wow, can't believe these showed up after all these years. Had 8 of them purchased from Direct Electronics (Barry)  opposite woodgrange park station late 70's early 80's era.
Used them to power 4x homemade Altec 816 copies loaded with McKenzie drivers, also from Direct Electronics.
Built a simple transistor inverter and run them in bridge mode, one bridged pair per cab. Think I was the only schoolkid around with a 1kw sound system. Remember it being scary loud but not that low.
You don't always get what you pay for, but you always pay for what you get.
Salvador View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Salvador Quote  Post ReplyReply Direct Link To This Post Posted: 22 March 2025 at 9:25am
Hello,
my name is Salvador and I'm from Barcelona.
I have read that you have diagrams of the AL 250 modules.
I have some PBC's but without serigraphy and I can't put the components, because I don't have schematic with the values and references. I would be very grateful if you could send me all the technical information (diagrams, etc) that you have available.
My e-mail address is: salvadoors@gmail.com
Thank you very much in advance.
Salvador
Post Options Post Options   Thanks (0) Thanks(0)   Quote Salvador Quote  Post ReplyReply Direct Link To This Post Posted: 22 March 2025 at 9:26am
Hello,
Salvador
Post Options Post Options   Thanks (0) Thanks(0)   Quote Earplug Quote  Post ReplyReply Direct Link To This Post Posted: 22 March 2025 at 10:13am
Originally posted by Salvador Salvador wrote:
Hello,
Salvador
Bon dia!   Smile
That would be AJ Audio, but if he doesn't reply I could try see if I still have that board lying around & send you a photo, or more details of the component values. Let's see...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Salvador Quote  Post ReplyReply Direct Link To This Post Posted: 22 March 2025 at 11:58am
 Ok thanks so much
Post Options Post Options   Thanks (0) Thanks(0)   Quote Salvador Quote  Post ReplyReply Direct Link To This Post Posted: 26 March 2025 at 12:24pm
It seems AJ Audio isn't responding. Can you help me?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Earplug Quote  Post ReplyReply Direct Link To This Post Posted: 26 March 2025 at 1:03pm
Yes. I sent you an email a few days ago. Did you not receive it? Maybe check your Junk box...
