Aperiodical loaded subwoofer |
FOO
Young Croc Joined: 23 December 2018 Location: Denmark Status: Offline Points: 815 |
Posted: 04 July 2019 at 5:04pm |
Can anybody explain to me why one would choose to build i aperiodical loaded subwoofer, instead of a traditional bassreflex loaded.
I am looking into Ohm subwoofers atm, and they seems to be using this type of design for the Cora-S and Eris subwoofers. To me they just look like regular BR enclosures. I have allready been reading some stuff on different sites, but i didnt get much wiser Cheers..
Tonskulus
Registered User Joined: 15 September 2017 Location: Finland Status: Offline Points: 425 |
Maybe they are just using those terms to make it look something special.. many manufacturers does that. To me, those seems to be typical bass reflex stuff too.
Edited by Tonskulus - 04 July 2019 at 5:16pm |
toastyghost
Aperiodic generally refers to a type of port
fatfreddiescat
There's several threads on diyaudio about that technique, puts it somewhere between a closed box and reflex flattening the impedance peak, Fulcrum use a variation for their passive cardioid boxes.
FOO
Okay so not some kind of magic stuff inside then :)
I have been reading quite alot on diyaudio, but every thread ends up in alot of mumbo-jumbo i really dont understand much of. And No one seems to have a 100% clear definition of what it is.. Well, some more reading might do me good i guess :) |
djgorey
Young Croc Joined: 29 December 2007 Location: S. Wales Status: Offline Points: 1306 |
Don’t know if you’ve seen this...
Gaffa tape is like the force in Star Wars - there's a dark side and a light side and it holds the universe together
cooky1257
Registered User Joined: 16 February 2011 Location: Wirral Status: Offline Points: 241 |
Basically its a leaky sealed enclosure
AndyWave
Registered User Joined: 30 March 2008 Location: Finland Status: Offline Points: 380 |
In a pa-loudspeaker there's more to this. One can achieve cardioid-like directivity pattern by placing the aperiodic reflex ports to the back-side corner of said enclosure. Look for Fulcrum Acoustics (Mr Dave Gunness may ring a bell?) and associated patent applications. All this has been trough in this very forum before |
torturing electrons since ......
