  New Posts New Posts RSS Feed - are hog scoop plans precised enough?
mikelink View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mikelink Quote  Post ReplyReply Direct Link To This Post Topic: are hog scoop plans precised enough?
    Posted: 06 January 2016 at 2:00pm
modelling a hog scoop on sketchup i found that the measurements of the internal parts come a little bit different, is it caused by the program or by the plans? i'd like to know before i cut the ply wrong
RaskaMC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RaskaMC Quote  Post ReplyReply Direct Link To This Post Posted: 06 January 2016 at 3:48pm
Hi mate,
We've 4 hogs and have built them with the plan! So no error in it ;)
Where do you have a pb?
bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bee Quote  Post ReplyReply Direct Link To This Post Posted: 06 January 2016 at 6:35pm
Ive built plenty and re drew plan in auto cad, did not notice any errors...
Post Options Post Options   Thanks (0) Thanks(0)   Quote mikelink Quote  Post ReplyReply Direct Link To This Post Posted: 07 January 2016 at 4:09pm
ok thank you, was just to be sure
SouthwestCNC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SouthwestCNC Quote  Post ReplyReply Direct Link To This Post Posted: 09 January 2016 at 9:16pm
Caused by sketchup.. Using a calculator measure and add together each intersecting part, line, joint etc between two extremities of a model in sketchup. I often find that the dimensions don't add up.. Nor do they stick, An 18mm extrusion in sketchup rarely actually measures 18mm. If i was asked to machine a sketchup file without redrafting the best tolerance i could guarantee is +/-1mm. As standard we guarantee 0.25mm.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SouthwestCNC Quote  Post ReplyReply Direct Link To This Post Posted: 28 June 2016 at 2:25am
I retract that last statement. believe i'm finding the same error. Posted it here:
