Are these 1850 horns right for this subbass use? |
Page <12 |
levyte357- ![]() Old Croc ![]() ![]() Joined: 27 July 2012 Location: UK, South East Status: Offline Points: 7958 |
As mentioned previously, Absolutely not !!!! If Reggae/DnB is not your main music material played, and you want sub section for general purpose use, stack of 4x 186 Horns, with Void V18-1000, PD1850, and with 4x ES18 Kick bins will meet your sub and kick section needs. If decent sub reproduction is also needed for Reggae/DnB, SuperScooper 18s loaded with Void V18-1000, and ES18 kick bins, will do a decent job, especially on bass heavy material. ES18s with strong 9mm Xmax driver, will really excel, 70-160hz, depending on driver. |
Vaso_Bobinata ![]() Registered User ![]() ![]() Joined: 21 May 2017 Location: Sofia BUL Status: Offline Points: 35 |
Hi mate i was wondering what to do with 8 PD1850/1 drivers. (left from a club upgrade)
1850 horn nothing below 50Hz X1 nothing over 100Hz (X1 very fast and easy to buld) not very all purpose designs :) WTF Any susgestions? Kind regards, V
Reviving another zombie thread !! What is your intended music type/crowd max size !? Seeing as you are posting here, won't suggest a Scoop perfect for the 1850, but would suggest 186 Horn. |
Page <12 |
