Are these drivers suitable for 186 horns |
danparrott
Registered User Joined: 17 December 2017 Status: Offline Points: 26 |
Posted: 17 December 2017 at 10:11pm |
Hi, complete newbie here. I am building some 186 horns following the speakerplans design and wanted to know whether these drivers are suitable for the cabs.
https://bishopsound.com/shop/18-inch-1000-watt-replacement-speaker-from-bishopsound/ Don't have any previous knowledge and not sure what I'm supposed to be looking for in terms of what makes a good driver. Any help or advice would be appreciated. |
danparrott
Would love to know what Thiele-Small Parameters are important so I dont have to ask in the future can just work it out
Edited by danparrott - 17 December 2017 at 10:18pm |
Dub Specialist Sound
Maybe at low Volume
when you strat driving them hard, the may tear the cones apart its risky a bit tbh, with unknown drivers really
smitske96
Young Croc Joined: 16 February 2016 Location: The Netherlands Status: Offline Points: 1092 |
Wouldn't put them in a horn.. Weak motor, high Qts and probably weak cone.
danparrott
Okay thanks, any recommendations below £200? Or would it be worth just getting the pd 186s
Mark James
I'm using mk1 paudio c18 650el in mine seems OK so far
knet94
Old Croc Joined: 31 March 2008 Location: NW London Status: Offline Points: 1510 |
Good to know they're still going strong Mark. |
danparrott
Had a look around and can't find any p audio c18-650el for sale, probably going to go with the pd 186s unless i can find a cheaper alternative, any amp recommendations for these? was thinking probably wiring 2 drivers in parallel and using an amp in bridged mode
Edited by danparrott - 18 December 2017 at 6:04pm |
njw
You're much better off spending out on decent drivers the first time rather than buying cheap stuff and blowing it all within a few months and then having to buy more expensive stuff anyway. It may mean it'll take longer to get all the drivers you need but fewer expensive drivers will usually outperform a higher number of cheap drivers anyway. |
