Ashly amps |
Dub Specialist Sound
Posted: 15 August 2018 at 9:06pm |
Is anyone aware of thesze amps,
bcus i need to know how do i swap of the polaity of the fan? or can the fan do that , do all fans do this or not got few amps and one of them the fan blowing the wrong way, on spec its suposed to blow from rear to front, it blowing the orther way..all orther ashlys are blowing the correct way i cant just turn the connector around as it doesw not fit, onlt fits one way , tryed to swap around the push on terminals , no luck so does seem ihave to turn the fan complety around thanks
njw
I'd just physically turn the fan around, done this myself when I've had different makes of amps with the airflow going in different directions in the same rack.
snowflake
fans should always blow onto the thing it is trying to cool. the turbulent airflow from blowing cools much better than the non-turbulent sucking
Yes snow i agree too tbh
looks like gona have to dill out the pop rivets :-(
Earplug
AC fans will not mind which way they are connected, but only run in one direction. DC fans will only work with correct polarity. Only way of changing direction is to move the fan!
Cheers Earplug, that explans it then, so ovsly its a AC fan
cheers bro
nickyburnell
Nice, very nice amp |
Thanks bro, tha are tbh, old skool heavyweight and proply built components wise
sorted now ive manged to drill out the pop-riverts and turn fan around now, and re bolt the fan back in also that fan weights a ton too wow fully built out of metal , and blows some serious air :-) thanks all
Edited by Dub Specialist Sound - 18 August 2018 at 11:07am |
