Audiohead ah1400 |
I-Linkin
New Member Joined: 09 October 2019 Location: London Status: Offline Points: 2 |
Posted: 18 October 2019 at 6:03pm |
Hi there, So Ive recently acquired an Audiohead ah1400 amplifier and on power up I ran into the following issue the right channel is significantly quiter then the left.So the the amp has some fancy lights on it one of which is "fault" which is infact off, thus not indicating a fault obviously incorrect.I've tested all the cables and they work just fine from my other amps. So my question would be what component/s inside the amplifier can cause a loss of volume if they are failing?
Many thanks,
