Awful noise from my EV P3000RL, RCM-24 problem |
liquidblue
Registered User Joined: 18 December 2014 Status: Offline Points: 20 |
Posted: 24 November 2018 at 12:08pm |
The amp was getting warmed up for a gig a while back, when after about an hour or so of play it stopped reproducing the signal and emitted this awful distorted scratchy fuzzing noise. It was driving two G subs loaded with PD186s wired at 4ohms per side. I believe something is wrong with the RCM 24 remote control module, as when I disconnect the module (two ribbon cables) and fire the amp up the problem is not reproduced. It does this whether it is receiving a signal or not. There are two red LED's on the bottom board of the RCM 24 module labelled D17 and D16. When I power it up one of the LED's (D17) flickers rapidly and the other is solid red. I'm not sure if that is relevant, but the more info the better. Please, any help or trouble shooting steps welcome.
spongebob
Young Croc Joined: 20 October 2010 Status: Offline Points: 1395 |
The chap you want is Neville Ward from Zenworks in Taunton.
luton_soundman
Old Croc Joined: 03 August 2010 Location: Bedfordshire Status: Offline Points: 4539 |
sounds like it was playing dubstep!
jacethebase
Thanks(1)
if you set the RCM module to 0-0 it will bypass the DSP.
www.stage2sound.com |
liquidblue
Do you mean on the CAN BUS address? Its always been set to 0-0...
jacethebase
Agh fair enough.
Just out of interest, do you use the RL's without using the internal DSP?
liquidblue
Erm... if I am honest, I've never plugged it into a computer. I've realised now that I should probably take a look at how its configured. Just waiting on a cable to arrive!
