  New Posts New Posts RSS Feed - B2 sub plans
B2 sub plans
Post Options Post Options   Thanks (0) Thanks(0)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 06 October 2019 at 9:12pm
Originally posted by murrat72 murrat72 wrote:
Yes can buy the exact drivers and have access to D&B audiotechnik amps, just want the speaker plans.
Then measure one of the boxes you should have access to.
Or maybe, stop lying to yourself and your customers.
Edited by toastyghost - 06 October 2019 at 9:12pm
ceharden View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ceharden Quote  Post ReplyReply Direct Link To This Post Posted: 07 October 2019 at 12:06am
Buy some of these, load with 18TBX100 (one of the recommended options) and you won't be far away...
ermannofusini View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ermannofusini Quote  Post ReplyReply Direct Link To This Post Posted: 18 November 2019 at 4:21pm
Hello, please, I need the Q-Sub plans.
Please, email: ermannofusini@gmail.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 18 November 2019 at 4:41pm
Rent a Q sub, and use your tape measure. Or just build any 18" reflex sub with the same external dimensions.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ermannofusini Quote  Post ReplyReply Direct Link To This Post Posted: 18 November 2019 at 4:54pm
Sorry, but I can’t afford that.
If someone has measured the e at internal plans can send me it?
Thanks
fusiniermanno@gmail.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 18 November 2019 at 5:51pm
If you can't afford to rent one speaker cabinet, then you should be looking elsewhere for your design. Not that you should be trying to copy it anyways.
It's just a small reflex box with a B&C driver in it, that's all. Tons of those out there, and simple to design your own.
Edited by toastyghost - 18 November 2019 at 5:52pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote ermannofusini Quote  Post ReplyReply Direct Link To This Post Posted: 18 November 2019 at 6:06pm
Ok, its a simple bass reflex, 15 x 15 holes but what is the depp?? There is any dumping material?
Can you answer me?
Post Options Post Options   Thanks (0) Thanks(0)   Quote ermannofusini Quote  Post ReplyReply Direct Link To This Post Posted: 21 November 2019 at 8:17am
koffertjes  Please! Send me the q-sub plans
Thanks!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote ermannofusini Quote  Post ReplyReply Direct Link To This Post Posted: 21 November 2019 at 9:50am
I can not see your personal email, please contact me
Thanks
bob4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bob4 Quote  Post ReplyReply Direct Link To This Post Posted: 21 November 2019 at 9:59am
STOP ASKING! IT IS ILLEGAL! NO ONE WILL HELP YOU.
Thank you Thumbs Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ermannofusini Quote  Post ReplyReply Direct Link To This Post Posted: 21 November 2019 at 10:01am
That’s not illegal!
If you reproduce the box and put the logo and say that is original it is illegal.
If you read the plans to study it is not illegal! Bye bye!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 21 November 2019 at 2:52pm
You’ve literally been told everything you need to know. If you can’t find the dimensions on the d&b site then you probably should put down the tools.
