  New Posts New Posts RSS Feed - B2F
B2F
David McBean View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote David McBean Quote  Post ReplyReply Direct Link To This Post Posted: 09 July 2020 at 8:38am
Originally posted by smoore smoore wrote:
How do you add a path length difference in hornresp between port and horn?
Calculate the combined power response then select the Tools > Output > Combined menu commands. Adjust the Path slider and press the OK button. Press F9 first if you want to permanently save the path value.
In the Loudspeaker Wizard, select the Power, Chamber and Combined options and adjust the Path slider.
Edited by David McBean - 09 July 2020 at 8:39am
bob4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bob4 Quote  Post ReplyReply Direct Link To This Post Posted: 23 July 2020 at 8:31pm
Wow, nice one! I see flared ports Tongue
snowflake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote snowflake Quote  Post ReplyReply Direct Link To This Post Posted: 24 July 2020 at 9:06am
yes I have some of the 6" precision sound flares. two of those back to back gives about the right port length.
I'm tweaking the plans to get it out of two sheets of 8'*4'. means making the access hatch out of aluminium and losing a couple of braces.
Post Options Post Options   Thanks (0) Thanks(0)   Quote snowflake Quote  Post ReplyReply Direct Link To This Post Posted: 25 July 2020 at 4:44pm
it took a lot of tweaking (including reusing handle cutouts as braces) but managed to lay it out onto two sheets of ply. will also need 4.8m of 44mm*120mm planed timber, 1m of 94mm*94m, 475mm*475mm aluminium panel (10mm or 12mm). will try and build it later in the summer.
