  New Posts New Posts RSS Feed - B2F
B2F
David McBean View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote David McBean Quote  Post ReplyReply Direct Link To This Post Posted: 09 July 2020 at 8:38am
Originally posted by smoore smoore wrote:
How do you add a path length difference in hornresp between port and horn?
Calculate the combined power response then select the Tools > Output > Combined menu commands. Adjust the Path slider and press the OK button. Press F9 first if you want to permanently save the path value.
In the Loudspeaker Wizard, select the Power, Chamber and Combined options and adjust the Path slider.
Edited by David McBean - 09 July 2020 at 8:39am
bob4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bob4 Quote  Post ReplyReply Direct Link To This Post Posted: 23 July 2020 at 8:31pm
Wow, nice one! I see flared ports Tongue
snowflake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote snowflake Quote  Post ReplyReply Direct Link To This Post Posted: 24 July 2020 at 9:06am
yes I have some of the 6" precision sound flares. two of those back to back gives about the right port length.
I'm tweaking the plans to get it out of two sheets of 8'*4'. means making the access hatch out of aluminium and losing a couple of braces.
Post Options Post Options   Thanks (0) Thanks(0)   Quote snowflake Quote  Post ReplyReply Direct Link To This Post Posted: 25 July 2020 at 4:44pm
it took a lot of tweaking (including reusing handle cutouts as braces) but managed to lay it out onto two sheets of ply. will also need 4.8m of 44mm*120mm planed timber, 1m of 94mm*94m, 475mm*475mm aluminium panel (10mm or 12mm). will try and build it later in the summer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote snowflake Quote  Post ReplyReply Direct Link To This Post Posted: 04 September 2020 at 12:51am
B&C 15RBX100 also looks good for this and is half the price of the BMS 15N830v2
must get round to building a prototype!
Teunos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Teunos Quote  Post ReplyReply Direct Link To This Post Posted: 04 September 2020 at 9:15am
Have you considered how you are going to mount the drivers in this arrangement?
Attraction/repulsion of the magnets will make assembly a pain especially if using ferrite drivers.
Best regards,
Teun.
DMorison View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMorison Quote  Post ReplyReply Direct Link To This Post Posted: 04 September 2020 at 1:27pm
The RBX's are not in the current catalogue, so it may be that it'll become unavailable once current stock at sellers is gone.
Post Options Post Options   Thanks (0) Thanks(0)   Quote snowflake Quote  Post ReplyReply Direct Link To This Post Posted: 04 September 2020 at 1:28pm
the whole driver baffle will be removable so I can mount the driver on the baffle before putting it into the speaker. bolts connecting baffle to the box can be positioned to make it easier to tighten the bolts. Rear panel and front panel are removable. I was imagining turning the box on one side and bolting down one driver, then flipping it 180 degrees and sliding the the other driver in underneath it and bolting it down. magents won't overlap that much but will only be 15mm clearance at one point. maybe I should cover the first with something if there is any danger of them attracting each other and chipping the magnets.
Edited by snowflake - 04 September 2020 at 1:37pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote snowflake Quote  Post ReplyReply Direct Link To This Post Posted: 04 September 2020 at 1:49pm
with B&C 15RBX100 driver. theres slightly more clearance than shown as the edge of the magnet is angled.
EDIT: looks like B&C have recently discontinued the 15RBX100
Edited by snowflake - 04 September 2020 at 2:32pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote snowflake Quote  Post ReplyReply Direct Link To This Post Posted: 14 September 2020 at 12:33pm
Beyma 15LEX1600Nd and B&C 15SW100 will both outperform the BMS and are cheaper. Confirmed they will fit after getting more detailed drawings with magnet dimensions.
