backup software |
Heathrow_B_line
Old Croc Joined: 11 January 2006 Location: United Kingdom Status: Offline Points: 7344 |
Posted: 08 August 2012 at 1:11am |
any good free back up software out there or do i have to buy one?
must be able to backup a network drive and run without too muc pc resources
herke
Registered User Joined: 04 November 2009 Location: Huddersfield Status: Offline Points: 171 |
I use software called second copy. Its about 30 dollars though but I would whole heartedly recommend it.
Very easy to understand and can tailor it exactly to what you need. For example I get it to back up my photo folder every night at 9pm, it will scan the folder and see what has changed then do an incremental backup. Its very minimal and you hardly know its there! |
shagnasty
Winrar and a batch file??
Jez_3phaze
Registered User Joined: 31 August 2009 Location: Derby UK Status: Offline Points: 162 |
Not sure if you want to backup files to a network drive, or backup a complete network drive as an image. Anyway have a look at these: Synctoy is free from “Microsoft” Drive image is free for a home licence.
toastyghost
CrashPlan.
ceharden
I just use the built-in Windows Backup utility which is happy backing up to a network drive. Or are you wanting to back up a network drive to some other media?
Heathrow_B_line
i wish to backup a network drive[s] to external hard disk
Jez_3phaze
I’m assuming you are using Windows, sorry I didn’t ask! Is the source drive a mapped drive on another computer or server, or is it a NAS? Either way as “Chris” said, providing the drives are available and mapped then “Windows backup” may be easier. This is what I use, unless I want to (sync/copy/echo) folders to some thumb drives.
I which case I use “Synctoy” as the files stay as files and not an image!
For an identical copy of a drive, I use the “drive to drive” function on “Driveimage XML”. But this will only work on drives physically connected to the same computer.
Tony Wilkes
I use this to back-up my workstation files to a Raid 1 NAS, maybe not the best way to do it but it works for me and is simple to use,
http://sourceforge.net/projects/freefilesync/ |
