  New Posts New Posts RSS Feed - Baltic birch dilema
Baltic birch dilema
northoftheriverswan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote northoftheriverswan Quote  Post ReplyReply Direct Link To This Post Topic: Baltic birch dilema
    Posted: 27 April 2023 at 10:53pm
Ive just moved from the UK to Australia. Baltic Birch Ply is super hard to get over here... especially in the west. I've heard that Poplar ply is a good alternative for box building.
Thoughts?
FOO View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote FOO Quote  Post ReplyReply Direct Link To This Post Posted: 27 April 2023 at 11:00pm
It's not... Not nearly as strong.
I would not build a touring box with it.
VECTORDJ View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote VECTORDJ Quote  Post ReplyReply Direct Link To This Post Posted: 27 April 2023 at 11:15pm
Birch from Finland  4 ft x 8 ft 13 ply 18mm with Weather  Proof Glue is the best.......VECTORSONICS   USA
fat_brstd View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote fat_brstd Quote  Post ReplyReply Direct Link To This Post Posted: 28 April 2023 at 12:41am
You can get Birch ply in Aus no problem (not sure if its baltic or not but its certainly good enough for making boxes), just need to find the right sort of timber merchant. You could go to plyco if you want to spend more money than you should but it can be found from around $250 AUD a sheet for B/BB at the moment.
Adrians Wall Sound System
Melbournes Rootical Warrior
Roots - Dub - Steppers
facebook page
csg View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote csg Quote  Post ReplyReply Direct Link To This Post Posted: 28 April 2023 at 6:26am
Bear in mind that lower grades are fine for box building if you are planning on paint / polyurea etc, buying CP/BB grade for instance is often a good deal cheaper, B grade is only needed really for fine finished furniture. The internal layup and density is exactly the same.
snowflake View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote snowflake Quote  Post ReplyReply Direct Link To This Post Posted: 28 April 2023 at 9:00am
poplar is okay for internals (weight for weight it is actually stiffer than birch) but external panels should be birch as it is far more dent-resistant.
Post Options Post Options   Thanks (0) Thanks(0)   Quote northoftheriverswan Quote  Post ReplyReply Direct Link To This Post Posted: 28 April 2023 at 11:49pm
Ok, great to know it doesn't need to be Baltic and B/BB Birch will do the job! Much appreciated, love your system btw @fat_brstd. Hope to pop east and hear it one day.
Edited by northoftheriverswan - 28 April 2023 at 11:55pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote fat_brstd Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2023 at 6:53am
Originally posted by northoftheriverswan northoftheriverswan wrote:
Ok, great to know it doesn't need to be Baltic and B/BB Birch will do the job! Much appreciated, love your system btw @<span style="font-family: Arial, Helvetica, sans-serif; font-size: 15px; : rgb251, 251, 253;">fat_brstd</span>. Hope to pop east and hear it one day.
That is a pretty good price tbh, I would go ahead and get what you need ordered.
The other thing that is worth a look on is FB marketplace, especially if you only need a couple of sheets. Its quite common to find sheets of Birch cheaper on there but you will want to check it out in person and if you don't have a big enough vehicle/trailer to pick it up don't even bother.
facebook page
This page was generated in 0.234 seconds.
