  New Posts New Posts RSS Feed - Bandpass Enclosure
Bandpass Enclosure
Five & View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Five & Quote  Post ReplyReply Direct Link To This Post Topic: Bandpass Enclosure
    Posted: 16 July 2017 at 11:24pm
Hi All Was Wondering If A Single Bandpass Enclosure Would Produce More Spl Than A Single Front or Rear Loaded Horn Like The Rino or Pd186 Horn
Let The Music Play
patryk1305 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote patryk1305 Quote  Post ReplyReply Direct Link To This Post Posted: 16 July 2017 at 11:47pm
No
Post Options Post Options   Thanks (0) Thanks(0)   Quote RoadRunnersDust Quote  Post ReplyReply Direct Link To This Post Posted: 17 July 2017 at 12:17am
Yes. No.
There are too many variables for anyone to give you a definitive, generalised answer
Buying myself a TFL-760H... piece by piece >.<
bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bee Quote  Post ReplyReply Direct Link To This Post Posted: 17 July 2017 at 12:49am
as above yes and no, at what frequencys, over a broad frequency band ect.. to many variables.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Five & Quote  Post ReplyReply Direct Link To This Post Posted: 17 July 2017 at 12:54am
Hi frequency would be 80 to 90hz
Let The Music Play
Post Options Post Options   Thanks (0) Thanks(0)   Quote RoadRunnersDust Quote  Post ReplyReply Direct Link To This Post Posted: 17 July 2017 at 1:40am
Building a box to cover 80-90 Hz is literally building a box to reproduce 2 notes...
Your x-over slopes would overlap so much you'd lose about 4dB output as well
BJtheDJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BJtheDJ Quote  Post ReplyReply Direct Link To This Post Posted: 17 July 2017 at 6:00am
The OP wrote "high frequency would be 80 to 90Hz" which is not a frequency range of 80-90Hz, it's a range that runs from whatever his required bottom end is to 80~90Hz; so (say) a bottom end of 30Hz with a top of 90Hz would be a range of an octave and a half, and from 40-80Hz would be an octave.
Only users lose drugs
Post Options Post Options   Thanks (0) Thanks(0)   Quote RoadRunnersDust Quote  Post ReplyReply Direct Link To This Post Posted: 17 July 2017 at 8:03am
Good point well made...
2 letter words are more invisible at 2AM
TheAmazingGanjaMan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TheAmazingGanjaMan Quote  Post ReplyReply Direct Link To This Post Posted: 17 July 2017 at 11:53am
i also read it as "Hi, frequency would be 80 to 90hz" same as the OP
Burn Baby Burn Voice Coil Inferno
Post Options Post Options   Thanks (0) Thanks(0)   Quote Five & Quote  Post ReplyReply Direct Link To This Post Posted: 17 July 2017 at 12:33pm
Sorry for the mixup guys when i said 80 to 90hz i ment the crossover point for the subs not to build a box that only covers 80 to 90 hz
Let The Music Play
Post Options Post Options   Thanks (0) Thanks(0)   Quote RoadRunnersDust Quote  Post ReplyReply Direct Link To This Post Posted: 17 July 2017 at 12:51pm
To get an answer to your question we also need the LF cut-off you're planning
Post Options Post Options   Thanks (0) Thanks(0)   Quote Five & Quote  Post ReplyReply Direct Link To This Post Posted: 17 July 2017 at 12:54pm
cut off point would be around 30hz
Let The Music Play
This page was generated in 0.102 seconds.
