Bandpass Enclosure |
Post Reply | Page 12> |
Five &
Registered User Joined: 22 May 2008 Location: Caribbean Status: Offline Points: 142 |
Posted: 16 July 2017 at 11:24pm |
Hi All Was
Wondering If A Single Bandpass Enclosure Would Produce More Spl Than A Single
Front or Rear Loaded Horn Like The Rino or Pd186 Horn
Let The Music Play
patryk1305
Registered User Joined: 13 December 2012 Location: United Kingdom Status: Offline Points: 488 |
No
RoadRunnersDust
Young Croc Joined: 03 December 2013 Location: United Kingdom Status: Offline Points: 561 |
Yes. No.
There are too many variables for anyone to give you a definitive, generalised answer |
bee
Old Croc Joined: 14 June 2011 Location: Middlesex Status: Offline Points: 4553 |
as above yes and no, at what frequencys, over a broad frequency band ect.. to many variables.
Five &
Hi frequency would be 80 to 90hz
Let The Music Play
RoadRunnersDust
Building a box to cover 80-90 Hz is literally building a box to reproduce 2 notes...
Your x-over slopes would overlap so much you'd lose about 4dB output as well |
BJtheDJ
Young Croc Joined: 28 November 2012 Location: Bristol Status: Offline Points: 886 |
The OP wrote "high frequency would be 80 to 90Hz"
which is not a frequency range of 80-90Hz, it's a range that runs from
whatever his required bottom end is to 80~90Hz; so (say) a bottom end of
30Hz with a top of 90Hz would be a range of an octave and a half, and
from 40-80Hz would be an octave.
It's a difficult choice, would you rather have:
A: A vegan son. B: An OnlyFans daughter |
RoadRunnersDust
Good point well made...
2 letter words are more invisible at 2AM |
TheAmazingGanjaMan
Registered User Joined: 27 January 2009 Location: sheffield Status: Offline Points: 148 |
i also read it as "Hi, frequency would be 80 to 90hz" same as the OP
Burn Baby Burn Voice Coil Inferno
Five &
Sorry for the mixup guys when i said 80 to 90hz i ment the crossover point for the subs not to build a box that only covers 80 to 90 hz
Let The Music Play
RoadRunnersDust
To get an answer to your question we also need the LF cut-off you're planning
Five &
cut off point would be around 30hz
Let The Music Play
