Barcode labels |
jacethebase
Posted: 10 December 2019 at 12:20pm |
Who makes the best barcode labels?
Need to be like hell to get off! Not wear away etc etc. |
www.stage2sound.com |
L8 ECU
Registered User Joined: 19 August 2015 Location: Wales UK Status: Offline Points: 77 |
Jace, Try the company below, I have been using them for many years. Make sure they understand your requirements - and get sample labels from them so you can test for yourself. Custom Labels Ltd |
JonB67
No real experience, but arent asset labels what you're after? Designed to be hard to remove and robust... worth a look.
toastyghost
Le Mark are of course the big boys in this field.
But the cost can be huge compared to just buying a decent printer and doing your own as needed. I wouldn’t consider them a deterrent to theft, at all. Nor good at recovering kit if it does happen. I see cables and boxes with other people’s labels on being used by companies at events all the time and some of it is definitely not sub-hired... If that’s your fear - and it is just that, fear - then smart water is going to give you far better reassurances. |
Digbethdave
Registered User Joined: 16 November 2018 Status: Offline Points: 406 |
Ptouch printer, 36mm tape with extra strong adhesive tape.
