Bass/mid bass |
Jamjah
New Member Joined: 22 July 2019 Location: UK Status: Offline Points: 5 |
Posted: 14 January 2020 at 1:20pm |
Greetings all
I have a pair of Eminence Kappa15a 8ohm 450 w. I want to build a mid range box. Eminence recommends a ported enclosure has anyone built one ? I would prefer a reflex design. Any build drawings out there? |
Jeferica
New Member Joined: 07 January 2020 Status: Offline Points: 7 |
hello. ported and reflex it.s the same. you can build a simple one with winisd and tune it. now depends it what fq range you want it to be.
Conanski
Old Croc Joined: 26 January 2006 Location: Ottawa, Canada Status: Offline Points: 2545 |
I didn't build the boxes but I have those drivers in dual 15 reflex bins running 80-1khz and they do a great job with little EQ needed over that range. The drivers need about 3.5-5 cu ft per internal volume.
