  New Posts New Posts RSS Feed - Bass/mid bass
Bass/mid bass
Jamjah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jamjah Quote  Post ReplyReply Direct Link To This Post Topic: Bass/mid bass
    Posted: 14 January 2020 at 1:20pm
Greetings all
I have a pair of Eminence Kappa15a 8ohm 450 w. I want to build a mid range box. Eminence recommends a ported enclosure has anyone built one ? I would prefer a reflex design.
Any build drawings out there?
Jeferica View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeferica Quote  Post ReplyReply Direct Link To This Post Posted: 14 January 2020 at 1:39pm
hello. ported and reflex it.s the same. you can build a simple one with winisd and tune it. now depends it what fq range you want it to be.
Conanski View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Conanski Quote  Post ReplyReply Direct Link To This Post Posted: 14 January 2020 at 7:52pm
I didn't build the boxes but I have those drivers in dual 15 reflex bins running 80-1khz and they do a great job with little EQ needed over that range. The drivers need about 3.5-5 cu ft per internal volume.
This page was generated in 0.064 seconds.
