Bass/Sub Bass Cab |
Page <123> |
Tom Umney
Joined: 26 February 2004 Location: United Kingdom Status: Offline Points: 4954 |
Posted: 10 May 2006 at 10:46am |
Super Scooper 18 will do 30hz-150hz.But I think thats in 4's.
Nigey-C
Joined: 06 February 2006 Location: Grimsby... FISH Status: Offline Points: 1342 |
Posted: 10 May 2006 at 10:48am |
but dont you get phase issues when using scoops and horns together??
Mark James
Joined: 15 January 2006 Location: rig side Status: Offline Points: 5306 |
Posted: 10 May 2006 at 11:43am |
yeah they do but they prolly can be cured, have you considered hd15 x1 and x12? [or similar ish arrangement] you could definetly design something that wil get you down to at least 30 hz with a v-18 in say a block of four [m~horn should do it] maybey some module horns [speakerstore] and some hd15s and mid top. or even just four module horns and a pair of x-tros should do what you want. 30hz is not unrealistic! , lab, x1, almost most of the band pass subs on this site will do 30 if not 32hz] er, module horn will do 35hz with just two cabs, so with four youd see 30hz at a guess, i recon minaximal had the best idea, design a horn thatl do 30hz with something like the v-18 or pd1850, or use a m~horn/lab horn and do a kick cab to play 80ish hz up [will depend on what youv got on exact freq] and some sensible mid and top. |
insert silly sentence here
Nigey-C
Posted: 10 May 2006 at 11:53am |
just thinking about it, how low woulda single tube 36 slim go? and would it be an idea to just extend the horn length by having another "wrap" around the outside of the cab making it bigger... |
Mark James
Posted: 10 May 2006 at 6:08pm |
if you know what your doing maybey? [i dont so i cant say for defo, but if done scientificaly enough and endowed with a decent driver and an apropriate back cahmber something like that may be done, dont quote me on that] maybey you could extend the 1850 / 186 horn [or basicaly design some thing new but this would be a possible starting point] and whack a serius horn length. minaximal knows a fair bit about 18" getting down to 30 hz and a bit lower, afaik his terra horn does this, and he proly wont give you the design , but hel prolly tell you how to go about designing your own [hes already posted a few pointers] go on design your own, something like a 186 thatl get down around the 30hz maybey 28/29 hz in a group of 4/8 might not have the output of a lab [might do though] but it should defo be doable, maybey if a few peeps threw you some pointers you could get yourself a rather nice, 30<100hz sub horn, like a true lab rival. |
Mark James
Posted: 10 May 2006 at 6:09pm |
or a 25<50 hz horn, the 1850 would seriusly be nice on top of that id imagine
tendril
Posted: 02 June 2006 at 7:53pm |
Do you absolutely HAVE to have a horn loaded system. Will you be doing mostly outdoor work?
Have you considered X1s and x12s. Would perhaps make a nice and tidy 3 way system with plenty of bass. |
Tendril
A mistake is a mistake only if one learns nothing from it. |
Nigey-C
Posted: 02 June 2006 at 8:08pm |
No i dont really plan on doing much outdoors (if anything)... I just thought horn loaded would give the best results. Especially in larger rooms... Room is about 35m x 20m with a capacity of around 1000... |
Mark James
Posted: 03 June 2006 at 7:07pm |
sometimes bandpass horn hybridscan produce better results indoors..... i dont know... |
gingerbiscuit69
Joined: 23 September 2005 Location: United Kingdom Status: Offline Points: 2540 |
Posted: 11 June 2006 at 8:49am |
ive done rooms up to 50m long with over 1000 people, using reflex without problems. as the FAQ says, horns are more efficient and throw sound, but reflexes can easily do it, easier to make, more compact lighter, just need a bit more oompth behind them. Line arrays are reflex...
Laurence G
Joined: 17 May 2006 Location: United Kingdom Status: Offline Points: 145 |
Posted: 11 June 2006 at 9:30am |
Line arrays are also horn....
Like the Martin W8L ;) |
gingerbiscuit69
Posted: 11 June 2006 at 12:01pm |
hitlers line arrays wernt! and the Nazi's invented the things!
Page <123> |
