  New Posts New Posts RSS Feed - Bassmaxx design
Bassmaxx design
Rengade Project View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rengade Project Quote  Post ReplyReply Direct Link To This Post Topic: Bassmaxx design
    Posted: 13 April 2005 at 10:21pm
Does anyone have the design for the bassmaxx copy or any idea how to design my own?
MUSIC SWEET,www.myspace.com/renegadeproject
_djk_ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote _djk_ Quote  Post ReplyReply Direct Link To This Post Posted: 14 April 2005 at 11:54pm
http://www.speakerplans.com/forum/forum_posts.asp?TID=594&am p;KW=bassmax
If you just leave the loading door off, it would be a scoop of the correct length.
http://www.speakerstore.nl/index.php?l=nl&pg=11&c=18
djk
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rengade Project Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2005 at 7:39am
Thank you for the help!!!
tb_mike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tb_mike Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2005 at 3:03am
Dont forget that excursion will increase HEAPS below cutoff so HPF at a high rate when using high power
djk-notice that the designer keeps saying its not a scoop,but we all know it is  Aslong as people like the sound who cares
Post Options Post Options   Thanks (0) Thanks(0)   Quote _djk_ Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2005 at 5:38am
I see he has changed the specs again on the B-zero.
He now claims ±3dB from 35hz~85hz
djk
Post Options Post Options   Thanks (0) Thanks(0)   Quote tb_mike Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2005 at 12:06am
Impedence dip at 41hz,double hump is uneven. Transient response has different shape vs labhorn.
http://homepages.paradise.net.nz/sbk1/ssi.htm
