  New Posts New Posts RSS Feed - Battery and amp advice
Dannyboy_086 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dannyboy_086 Quote  Post ReplyReply Direct Link To This Post Topic: Battery and amp advice
    Posted: 24 July 2010 at 11:23pm
Hello all,
I've recently purchased 2x hemp acoustics fr4.5c speakers (v similar to fostex 126/127)
Had a lepai t-amp but it's not working so ordered another one
Now just need a battery, was thinking about getting this battery, its a chinese lipo one and handily it has an output jack that would fit the amp.
If not, I assume I would need a 12v battery, SLA, then connect that with 2 wires wire that into a 5.5/2.1mm power jack then put that into the amp?
Any other battery ideas, how much AH would I need to power the amp at 8ohms for 10 hours or so?
Have also thought about buying two of these, then wiring them up in parallel? to double the ah capacity
audiomik View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote audiomik Quote  Post ReplyReply Direct Link To This Post Posted: 25 July 2010 at 11:15am
Re: "Have also thought about buying two of these, then wiring them up in parallel? to double the ah capacity"
these will self discharge if connected in this manner
