Battery powered Tham12 Sub - Update 2023-08-19 |
Page <123 |
Author | |||
roopes ![]() Registered User ![]() Joined: 04 January 2016 Status: Offline Points: 75 |
compared to a soundboks3 the bass is much much better and deeper, exactly what i was looking for. The tham12 moves ALOT with very little power! Super efficient
Hooked up 4x 4fe32 faital pro to a 2 channel china amplifier (only using 1 channel 50w 24v) its very loud but the soundboks beats it in the amount of spl but i have ordered another tpa3255 monoblock to hook up to the faitals and a 36v battery. The goal is to get approx same spl as the soundboks3, about same size but much more bass out of it. Worst case ill add another 4 4fe32 to get an array of 8 and use a 2x300 tpa3255 amp ![]() Edited by roopes - 19 August 2023 at 4:17pm |
slaz ![]() Old Croc ![]() ![]() Joined: 27 November 2009 Location: London E2 Status: Offline Points: 2699 |
NIce. Got a bathroom scale handy ? What does it weigh (lets say without amp+battery) ? |
18,1kg with battery and amp, 15,8kg without. It’s lighter then I expected which is a good thing
Thats good going for a plywood box. Is it 15mm birch ply ? Hmmm.... would be fantastic (for me) to build a THAM12 from hexalite (I have enough of it to make one) - but those angled cuts etc. would make it hellish difficult methinks. Would divide the weight of the enclosure itself by about 2/3 !! ... but would also need to be handled very carefully. Damn I've had that stuff for _years_ now - keep threatening to use it to build a speaker box, but ain't got around to it yet <g>. |
its 15mm construction plywood i think its pinewood or something similar, not birch, all the birch is damn expensive now when Russia is not allowed to export it anymore
Are you putting a delay on the soundboks (or other mid-top) when used with the THAM12 ? How are you getting on with that DSP ? I ordered one to tinker with - still waiting for it to rock up ....
no delay, I have no idea how to use it! Think i read in some tham12 thread that the delay is so small that it doesnt make too much of a difference In fact about the DSP I just started to experiment with it, and to set gain and crossovers its great! a little hard to get the crossover to slope very steep like 48 db/oct but i think i got it close enough. Got some virtual bass on the small line array and it sounds great! I didnt find a way to make the mid/treb mono output but im soon getting a mono amplifier so that should be good enough. I can also just use the soundboks as mid/high but i really want to use the line array because of its small size and weight, might just build a new tower with 8 speakers instead of 4. And i also want to start messing around with REW but for that i need a calibrated mic, so maybe later on! some pics of the EQ, feel free to use the same values as a base (if you can read it ![]() Highpass (The tham12 have a 110hz cutoff freq built in the amp) ![]() Low pass ![]() Edited by roopes - 03 September 2023 at 7:23pm |
DiegoALM ![]() New Member ![]() Joined: 03 September 2023 Location: Almeria Status: Offline Points: 3 |
Great Build!! Could you send me the plans you have used? I dont know the measurements of the sheets i have to cut
Here you have the plans https://www.martinsson.cc/blog/index.php?entry=THAM12
Uploaded a small sample at 30% volume, the room (45 sqm) cant handle much more without everything rattling (a lot of shit in the room). Its recorded on my iphone the the quality isnt the best, sorry!
Ah OK .... what software is that you're using ? Is there somewhere that lists the i/f s/w thats compatible with that DSP chip/board ? The aliexpress vendor I bought from has no info whatsoever on that :-( |
The software is called ACP Workbench, ask the seller for the software and in the file you will find a manual in english maybe you can find what your are looking for.
Page <123 |
