  New Posts New Posts RSS Feed - B&C 15SW115
B&C 15SW115
UpComingSound View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote UpComingSound Quote  Post ReplyReply Direct Link To This Post Topic: B&C 15SW115
    Posted: 27 March 2020 at 6:47pm
Do any one have any building plans for a single box for B&C 15SW115
smitske96 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitske96 Quote  Post ReplyReply Direct Link To This Post Posted: 28 March 2020 at 12:18pm
What are you looking for?
-Compact? (dimensions etc)
-Extension? (>40 Hz?)
-Max SPL?
Normally you can pick two. Also keep in mind that the SW115 needs some proper power.
BASSHORSE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BASSHORSE Quote  Post ReplyReply Direct Link To This Post Posted: 28 March 2020 at 3:46pm
mini scoop
Post Options Post Options   Thanks (0) Thanks(0)   Quote UpComingSound Quote  Post ReplyReply Direct Link To This Post Posted: 28 March 2020 at 6:01pm
yes mini scoop or single reflex some ting compact give thanks
Noud View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Noud Quote  Post ReplyReply Direct Link To This Post Posted: 28 March 2020 at 6:03pm
This caught my attention last month.
looks very good! hornresp record are available.
Facebook group
High Order Quarterwave Society (DIY Paraflex & Super Planar dev community)
Direct link
https://www.facebook.com/groups/bassaz/permalink/2782412598440516/
Edited by Noud - 28 March 2020 at 6:03pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitske96 Quote  Post ReplyReply Direct Link To This Post Posted: 31 March 2020 at 9:47am
I saw your pm and respond on the topic (so more people can find some info).
If you want compact, miniscoop isn't the way to go. The BR option will be the compact option, miniscoop is bigger but gives you more SPL. You have to specify your max dimensions. If you are eventually going the BR way, I have a plan laying around. I am going to build it myself in about a month (with 15TBW100-8).
taurusty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote taurusty Quote  Post ReplyReply Direct Link To This Post Posted: 31 March 2020 at 2:35pm
Hey Smitske! Are U saying a 15DS115 is less efficient than a 15TBX/W 100?
Post Options Post Options   Thanks (0) Thanks(0)   Quote UpComingSound Quote  Post ReplyReply Direct Link To This Post Posted: 31 March 2020 at 3:51pm
i guess around 21 X 17 X 24
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitske96 Quote  Post ReplyReply Direct Link To This Post Posted: 31 March 2020 at 5:22pm
Personally I would use the 15DS115 in a paraflex or something. 15TBW suits a BR perfectly and almost is much cheaper.
@UpCominSound
With those dimensions the only option really is BR, miniscoop will be much bigger. You do need a large port for such drivers, atm I have around 420 cm2.
Post Options Post Options   Thanks (0) Thanks(0)   Quote UpComingSound Quote  Post ReplyReply Direct Link To This Post Posted: 31 March 2020 at 8:13pm
plans for a single reflex
