  New Posts New Posts RSS Feed - B&C 15tbw 100 plan
B&C 15tbw 100 plan
djrobs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djrobs Quote  Post ReplyReply Direct Link To This Post Topic: B&C 15tbw 100 plan
    Posted: 01 April 2022 at 10:09pm
Hi iam looking for br box plans for the B&C 15tbw 100
Does anyone have one ?
Thanks / rob
Regards Rob
JonB67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JonB67 Quote  Post ReplyReply Direct Link To This Post Posted: 02 April 2022 at 8:25am
Id suggest you design your own.
Download WinISD and have a play.  It's not that hard and you'll get help on here with any questions.
Allows you to make the compromises you feel are right for your requirements.
You can then sketch up a box and build it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote djrobs Quote  Post ReplyReply Direct Link To This Post Posted: 02 April 2022 at 8:48am
Okey i Will give it a try,
Thanks
Regards Rob
Post Options Post Options   Thanks (0) Thanks(0)   Quote JonB67 Quote  Post ReplyReply Direct Link To This Post Posted: 02 April 2022 at 8:54am
Cool. Don't be put off, the skills are worth learning. Once you realise what you're achieving its pretty interesting.
Post Options Post Options   Thanks (0) Thanks(0)   Quote djrobs Quote  Post ReplyReply Direct Link To This Post Posted: 02 April 2022 at 9:54am
True :)
Whats the most importen Things to look for in the winisd
The sketchup thing, do i have to do it manuellt?
Regards Rob
Post Options Post Options   Thanks (0) Thanks(0)   Quote JonB67 Quote  Post ReplyReply Direct Link To This Post Posted: 02 April 2022 at 10:09pm
Winisd won't draw you a cabinet, just help you find the parameters (volume, port size and length) for you to design one.
You can then either just do it with a pencil and paper (that's all i do) or design in cad if you have that kung fu and want to get it made with cnc.
