B&C 18SW115 enclosure design |
Page <1 678 |
MarjanM
Joined: 10 February 2005 Location: Macedonia Status: Offline Points: 7844 |
Posted: 10 January 2018 at 11:32pm |
Compared to whats out there for way less money? Yeah, it is shit.
bcs
Joined: 27 September 2010 Status: Offline Points: 216 |
Posted: 11 January 2018 at 8:08am |
Hi Kyle What in your opinion would be a decent tapped horn, the cyclops maby? I am also looking to get a few cabs made around the similar driver. Mike
bass*en*mass
Joined: 03 September 2009 Location: "unknown" Status: Offline Points: 4007 |
Posted: 11 January 2018 at 4:24pm |
keystone subs will go lower than cyclops and are tried and tested with 18sw115s..
sn95
Joined: 10 March 2013 Location: USA Status: Offline Points: 351 |
Posted: 11 January 2018 at 6:26pm |
Crashpc
Joined: 26 February 2008 Location: Czech Republic Status: Offline Points: 539 |
Posted: 11 January 2018 at 6:30pm |
Almost everything goes down to 30Hz. It depends on the actual power output it delivers at this frequency.
bass*en*mass
Posted: 11 January 2018 at 6:44pm |
according to the sims i have seen/afaik/remember, the regular cyclops are not tuned very low.. around 50hz.. the extended version propably rather 40ish hz, keystone regular around 45hz, extended about 35hz?
MarjanM
Posted: 11 January 2018 at 7:28pm |
Cyclop, TH118, Keystone, all not very big boxes, so 40hz real output with a -3db point at 35ish HZ is what you realistically get from them.
For real 30hz performance, you should look at something like the OT horn or similar design. Bigger boxes needed for sure, so it is all a compromise. Once you start thinking truck pack, things get complicated fast.
bcs
Posted: 11 January 2018 at 7:57pm |
I am not so experienced as you guys here but if 30hz is needed wouldn't band pass cabs be better to use, maby X1?
Crashpc
Posted: 11 January 2018 at 10:02pm |
Better is also very broad term. It gives out great SPL for one box, but has also many disadvantages.
nickyburnell
Joined: 06 February 2005 Status: Offline Points: 4408 |
Posted: 12 January 2018 at 8:12am |
Standard Cyclops has 40hz with Fane Prime even though Staip said 45. Has a very reflex sound.
Not an enjoyable build, think about getting bracing in, need a carpenters mind, or one better than mine :) Very high attack and subby cab though. Only time I have ever liked sound of non reflex cab in small space Sadly the FSP link is broken. Link below (the builder) was me. https://forum.speakerplans.com/beware-the-one-eyed-monster_topic39393.html Edited by nickyburnell - 12 January 2018 at 8:15am |
DJ Flowtunes
Joined: 30 August 2018 Location: Maryland Status: Offline Points: 2 |
Posted: 30 August 2018 at 9:18pm |
Hello I know this may be late but did you make the box yourself. Cause I am also interested in the driver and I am looking for the best of both worlds that is the best sound with the smallest possible size and weight. That's why I like your box. Please if you didn't build it yourself who did. I am based in Maryland and have been trying to get a good box builder. Any help will be appreciated
Edited by DJ Flowtunes - 30 August 2018 at 9:19pm |
DJ Flowtunes
Posted: 30 August 2018 at 9:20pm |
Page <1 678 |
