  New Posts New Posts RSS Feed - B&C 18TBX100 / Fane 18SB1000
love2all View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote love2all Quote  Post ReplyReply Direct Link To This Post Topic: B&C 18TBX100 / Fane 18SB1000
    Posted: 10 September 2017 at 11:34am
If your reading this - i hope you are well and can help me with a quick response.
Is a B&C 18tbx100 bolt pattern compatible with a fane 18sb1000 bolt pattern? Box already cut for the fane but i want to try the B&C.
Thanks
nickyburnell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickyburnell Quote  Post ReplyReply Direct Link To This Post Posted: 10 September 2017 at 12:05pm
Check the PCD measurements in specs sheets.
levyte357- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 10 September 2017 at 1:16pm
If Bolt pattern, drilled for FANE "Internal pattern", should work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote love2all Quote  Post ReplyReply Direct Link To This Post Posted: 10 September 2017 at 2:39pm
Thank you sir
Marvin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Marvin Quote  Post ReplyReply Direct Link To This Post Posted: 11 September 2017 at 10:05am
As far as I am aware B&C bolt patterns won't fit standard bolt patterns. They are out by a few mm
Post Options Post Options   Thanks (0) Thanks(0)   Quote love2all Quote  Post ReplyReply Direct Link To This Post Posted: 44 minutes ago at 6:26pm
Aany thoughts about pros and cons between these two drivers in a es18?
